Utah Evos
Old Oct 2, 2009 | 08:07 PM
  #29716
TwoFour's Avatar
Originally Posted by mikefisher_4g63
Well i just installed it to run directly from the turbo to the nipple pointing towards the motor and the wastegate to the nipple pointing at the ground. and still gettingcut at 8psi. gauge is maybe a week old. where does your guys vacuum sit? mine stays around -16-18, i am going to have to say i have a bad leak somewhere.
evilbloodbrota i can stop by anytime this morning. if you even want to look at the pos, its just making me angry. haha and my solenoid is capped, i will try running a hose to both nipples.
Do a boost leak test yo
Old Oct 2, 2009 | 10:19 PM
  #29717
chuckbyu's Avatar
The stock wastegate spring opens at 11-12lbs of boost. The solenoid and MBC just bleed off pressure to "trick" the wastegate into opening at higher boost. 8 lbs of boost is not possible unless you have a boost leak or you gauge isn't functioning right. Unless the leak is coming from the MBC itself, they way you have it hooked up is not causing the problem. There is something else going on. Good luck.
Old Oct 3, 2009 | 02:38 AM
  #29718
Samuelsan's Avatar
Veteran: Army
Originally Posted by Jay644
I dj for the parties I have. **** is tough. I dont have any pro equipment. All I use is my macbook and a cheap surround sound I have laying around. That and some turntable software I found online.
Would you happen to know anything about equipment? Like a Vestax VCI - 300 particularly?
Anyone checkin out Klaas down at the rail tonight?
Old Oct 3, 2009 | 09:50 AM
  #29719
Evolution IVGSR's Avatar
Thats a negative. Working until the early morning keeps me from waking up early. Usually don't roll out of bed until 1pm Might be working tomorrow also.
I work late 4 nights a week and I have school in the morning at 7 am I need to get a different schedule or different job maybe
5pm to 3:30am sometimes later than that if I want.
Ya I feel you there man I did 4:30pm to 3am last night and tonight is 4pm till who knows when
Old Oct 3, 2009 | 10:58 AM
  #29720
mikefisher_4g63's Avatar
i am hoping its just a simple leak. but idk what to do. fml.
Old Oct 3, 2009 | 11:01 AM
  #29721
wesside's Avatar
Who was looking for a shep built trans? Timmay was that you?
Pm me
Old Oct 3, 2009 | 11:02 AM
  #29722
wesside's Avatar
Double postage
Old Oct 3, 2009 | 12:38 PM
  #29723
Jay644's Avatar
I dont know anything about the equipment.
I'm still getting used to it. Definitely have it a lot easier since I can sleep in. I cant function without atleast 9/10 hours of sleep. Wish it was less. Just have to train my body for it maybe.
Old Oct 3, 2009 | 02:15 PM
  #29724
i really want this problem to be a leak in my BOV, i have my 2nd gen eclipse GST BOV in my garage and i was thinking i would slap it on there to see if it helps at all. but i may not hassle with it until the 6th (when my forge BOV gets here) i went through all my stock IC piping they all seemed tight and snug. but ordered MUSE upper and lower ic piping, just to be safe ;D..
and can anybody post a pic of how they have their boost gauge set up? idk if im doing mine correctly.
EDIT: and it sure only feels like im hitting low psi. not much pull. at all. i hit cut at 4500-and up ish in first gear
Old Oct 3, 2009 | 03:23 PM
  #29725
Jay644's Avatar
You definitely have a huge boost leak like others have stated. Your not getting "cut" as you put it. "Cut" generally means the engine is not able to climb to any higher rpm than the rpm your getting cut at. Such as a rev limiter or fuel cut.
By what you said, it appears your able to go beyond 4500rpms its just your not building anymore boost.
Old Oct 3, 2009 | 06:23 PM
  #29726
suprawillis's Avatar
If you have access to compressed air, then remove your MAF and intake from your intake pipe. Grab a thick ziplock bag, or a garbage bag, get a clamp, and clamp the bag around your intake pipe. Take the vacuum line off the blow off valve, and compress the air inside the vacuum line and listen for leaks.
Old Oct 3, 2009 | 07:14 PM
  #29727
MR BURTON69's Avatar
There you go Bobby, i have an Avatar pic finally!
Old Oct 3, 2009 | 07:27 PM
  #29728
signature working??? it is
Old Oct 3, 2009 | 08:03 PM
  #29729
wesside's Avatar
**** I offer to look at it, get text..see ?'s pop up on forums and it's all just a waste of time I swear sometimes Do a boost leak test dammit
Old Oct 3, 2009 | 08:15 PM
  #29730
TwoFour's Avatar
Also make sure to get silicone couplers for all that piping
