04-06 Ralliart Engine/Drivetrain (no forced induction)
RRM Downpipe!!! [merged]
Old Apr 5, 2005 | 06:16 PM
  #46
otter's Avatar
EvoM Administrator
Just put my downpipe on yesterday evening. It SCREAMS!! It's loud when you're punching it, but it helps the car haul even faster. It takes the deep flow from the magnaflow muffler and adds a raspy higher pitched sound to it. It's obnoxious, but roll up your windows and turn up the stereo and it's easy to ignore. The power gains are worth it.
I had a heck of a time getting the old pipe off, though. This winter's salt had rusted the two rear nuts onto the bolts It took a lot of swearing and torching to get the damn things off. Also put defoulers on the rear O2 sensor, and no CEL light yet.
Old Apr 5, 2005 | 06:48 PM
  #47
ErikT's Avatar
^^^ Put any resonators in?
Old Apr 5, 2005 | 07:51 PM
  #48
ErikT's Avatar
Question: I have a Magnaflow Muffler (not straight through) and my exhaust sounds sweet right now. Deep and throaty... no problems whatsoever. If I add the downpipe, what will I have to do to my exhaust system to keep the same relative sound quality? Resonators? If so, where I can I buy these? Are there any other options?
Also, I've heard the only real restriction on our exhaust system is that crimped down section of pipe before (towards the engine) the cat. Is the fact that the DP elimnates this the reason for its effectiveness? If not, what does the DP do other than that?
In other words, what is wrong with the stock one?
Thanks for reading.
Old Apr 5, 2005 | 09:44 PM
  #49
ROCK's Avatar
The performance gains are hard to beat. Add another resonator. That will help with the noise.
ROAD/RACE
Old Apr 5, 2005 | 10:34 PM
  #50
otter's Avatar
EvoM Administrator
The stock downpipe has that crimp in it which causes all that loss in power. The only resonator I have right now is the stock one in the mid-pipe. You have a few options with RRM's downpipe - learn to ignore the noise; add a resonator (what I'll probably do); or add a high-flow cat. You'll still have the benefits of the aftermarket pipe since that kink in the pipe will be gone. Plus, RRM's pipe just has smoother, better flowing bends in general. Looking at the stock pipe then RRM's pipe is night and day.
Old Apr 6, 2005 | 07:02 AM
  #51
ROCK's Avatar
Ours does flow so much better. Plus it is ceramic coated and far superior to stock DP in every way.
ROAD/RACE
Old Apr 6, 2005 | 07:25 AM
  #52
AlkalineTrio124's Avatar
No doubt about that... It's been about 2 weeks I've had it on... You can TOTALLY tell the gains in power and don't really feel anything lost in the low end, which I was really happy about because I was worried about losing tq & hp low... but it's designed great & that's not a worry at all... Next up Piggyback!!! ha ha...!!!
Old Apr 6, 2005 | 11:13 AM
  #53
ErikT's Avatar
So is a resonator just a larger diameter tube situated somewhere in the exhaust system? If I buy a glasspack and weld it into the midpipe is that a "resonator"?
Old Apr 6, 2005 | 12:25 PM
  #54
otter's Avatar
EvoM Administrator
A resonator is a section of pipe that is made to absorb/change the sound frequency of your exhaust to get rid of the higher frequency tones that are so annoying (such as the raspy honda fart can sound)
Old Apr 6, 2005 | 07:59 PM
  #55
ROCK's Avatar
Correct Otter!
ROAD/RACE
Old Apr 11, 2005 | 06:52 AM
  #56
ralliart1979's Avatar
Magna Flow exhaust huh. That would be the reason that it sounds obnoxious. I have the Evo 5 Greddy and th rrm down pipe and it sounds low and great. Right parts for the right job. What you spend is what your going to get cheap and maybe fast, moderate and maybe fast or expensive and right parts and get HP&TQ.
Old Apr 11, 2005 | 07:35 AM
  #57
ROCK's Avatar
GLad you found a quiet combo.
ROAD/RACE
Old Apr 12, 2005 | 07:26 AM
  #58
Magnaflow is not necesarily the "cheap route"
Set up is good... reason it sounds obnoxious is because I'm running w/o a cat...
Old Apr 12, 2005 | 10:00 PM
  #59
ROCK's Avatar
True Alkline.
ROAD/RACE
Old Apr 13, 2005 | 06:37 PM
  #60
coolmivec's Avatar
ey rock ,when rrm is gone make the underdrive pulley ? . its goning to be a nice up grade i think. btw always hoping that everything is all right up there ,ok take care dude
