04-06 Ralliart Engine/Drivetrain (no forced induction)
OBX Headers
Old Apr 20, 2013 | 03:20 AM
therocky4's Avatar
OBX Headers
Hey Guys,
Have been a proud owner of a 04 Ralliart for some months now and this is my first post over here
I was just wondering that anybody has these OBX headers installed in their RA?
http://www.obxracingsports.com/products.php?pk=1777#
How do they perform? They seem to be cheaper than the ones listed at RRM!
Also my front shocks are leaking oil and the rear ones are already dead! I am thinking of replacing them with an aftermarket coilover set! The problem is that I could only find these at RRM and Ebay, which are located in the states. Anybody knows of any good ones that I can get here in Ontario?
Thankx
Old Apr 20, 2013 | 09:45 AM
lanzerralliart's Avatar
EvoM Super Moderator
Welcome to Evom
Here's a few threads on the obx headers ....
https://www.evolutionm.net/forums/04...alled-pic.html
https://www.evolutionm.net/forums/04...header-dp.html
https://www.evolutionm.net/forums/04...er-review.html
I can't really help with buying stuff in Canada but there's a lot of Canadians here that will pop in soon enough
Be sure to use the search feature as most of the questions have been answered a few times. Also be sure to post up in the link in my signature
Old Apr 20, 2013 | 10:54 AM
CrAnSwIcK's Avatar
which coilovers are you talking about?
check the manufacturers website for canadian dealers.
Old Apr 20, 2013 | 11:30 AM
DirtyRalli's Avatar
I have the obxheaders and i like them alot.... Your going to have to weld a cat on it though if you wNt to pass emmisions and if you dont like it loud.... I never did lol i like the sound and the cat is restrictive anyway but i get hasseled by the popo.... As for coils.... BC racing is the best bang for the buck i ordered the, right off the bc racing website cost about $1000 not too much of a diffrence from buying from a dealer
Old Apr 20, 2013 | 09:37 PM
therocky4's Avatar
Perfect Thankx a lot guys for the info. Lol I have to save a lot of money before I order these things in.
I am having an issue with the cv axle right now. It is making a lot of noise when I turn and drive! I went to the specialists just to find out that they are ceased and do not come out easily (as they are rusted pretty badly) They will have to break in and afterwards replace the wheel bearings too! Probably going to be a $500 Job!
Old Apr 20, 2013 | 11:18 PM
Raikiri's Avatar
that sounds like an understatement lmao you're probably looking at closer to a grand i'd say
Old Apr 20, 2013 | 11:48 PM
therocky4's Avatar
I am just assuming it to be $500 because the mechanic told me its going to cost me $300 before he found out that the wheel bearings also need to be changed. The bearings cost $70-80 each, so my estimate would be around 500-600 now!
Lool at the Mitsubishi dealers! I called them in to ask for the price and they told me something around 2K without the installation and the wheel bearings!
Old Apr 21, 2013 | 12:06 AM
Raikiri's Avatar
hmm... i'd estimate closer to 700 just cause i'd assume about an hour of labor per bearing then add in taxes
Old Apr 21, 2013 | 02:12 PM
therocky4's Avatar
Lets see what the mechanic says! Ill post it here
Old Apr 22, 2013 | 05:22 AM
2006_RA's Avatar
Hello, welcome to the forum.
Assuming you meant to say that your axle is seized then see this thread:
https://www.evolutionm.net/forums/04...-ralliart.html
Check CAPS off Merivale or off Innes road for the parts you need or these guys http://www.autopartsottawa.ca.
Warning, removing the seized axle can lead to needing a new ABS sensor too.
There is a place on Gladstone between Bank & Bronson that rebuilds OEM axles for a decent price.
Good luck.
Old Apr 22, 2013 | 12:25 PM
therocky4's Avatar
Good luck.
Hey Thankx a lot bro for the info . The first thing that I did was to go to CAPS and they were asking $200 for both when I gave them my old one! But they said that even their supplier is out of stock so they need to back order which would take atleast 3 weeks to reach their supplier. I went to Canadian Tire and they told me the same thing.
My mechanic suggested that I go to the specialists for CV in Gatineau named "A1 CV Tech" (website: http://www.a1cvtech.com) and get it checked from there. Now I am going over there tommorow for the CV but its a good thing you just told me about the ABS sensor I am just going to give him a call right now to inquire about it!
Do you have phone number/address for the specialist on Gladstone?
Thankx a lot.
Old Apr 23, 2013 | 05:54 PM
therocky4's Avatar
I just got my CV done today. I am amazed at the guys at A1 CV Tech. Even though the axle was seized but they still managed to take it out and rebuild it without breaking the wheel bearing as well as the ABS sensor still intact and working! It cost me only $300 and they have given me a lifetime warranty for the job!
I was really worried after I read one of the topics posted over here regarding the changing of the front wheel bearing ( https://www.evolutionm.net/forums/04...alliart-2.html).
You guys should definitely check these guys out if you live in or around Ottawa/Gatineau area for CV, Wheel Bearing, Struts etc related work.
link: http://www.a1cvtech.com/
The next Job I probably need is to replace my suspension with the Aftermarket Coilovers. Anybody has tried out these D2 sets from Ebay?
link: http://www.ebay.ca/itm/36-WAY-ADJUST...#ht_2846wt_952
Or should I get the BC or Megan ones?
Old Apr 28, 2013 | 08:17 PM
JTCB's Avatar
For the same price I would go with the Tein ones there the best quality.
As to the OP. I got the OBX Header/Dp combo from what I can see there seems to be a little more power but ever since ive installed them I hear a ticking sound seems like its coming from the header.
Old Apr 29, 2013 | 03:32 AM
OttRalliart05's Avatar
YA Marco at CVTech is really good at what he does. I had mine rebuilt there 3 times before he told me he can do an upgrade to handle the extra power my Turbo RA makes, so far 2 years no issues.
gui dube987
18
Apr 24, 2015 05:21 PM
gui dube987
35
Feb 13, 2014 12:09 PM
efecitiy231
Lancer Engine Tech
37
Feb 5, 2011 06:06 AM
Matt_Jagg7
May 22, 2009 09:19 PM
BBG327
11
Oct 30, 2008 05:36 PM
