for the last month or so
Old Dec 12, 2007 | 03:43 AM
jessep's Avatar
the radiator fan stays on all the time even for a little when i turn the car off . the gauge shows me running close to hot but i have plenty of coolent and no linking i can see.
also the headlights slightly flicker time to time .
the only thing i've had done i that time is a new amp and nav headunit .
thanks
Jesse P
Old Dec 12, 2007 | 04:22 AM
otter's Avatar
EvoM Administrator
Have your cooling system checked out. Something's not right, but we don't have enough info to make a diagnosis. I'd start with checking to see if your thermostat is working properly or not, then go from there.
Old Dec 12, 2007 | 06:00 AM
PR_Mivec's Avatar
there a tsb about that.. your fan control module went to hell, go to the dealership and they should replace it free; is a 10 minute thing
Old Dec 12, 2007 | 06:25 PM
06RedRalli's Avatar
+1^
Old Dec 12, 2007 | 11:07 PM
bruce988jl's Avatar
search and you'll find part no. for the fan controller if you're no longer under warranty...
Old Dec 18, 2007 | 10:48 PM
reTro's Avatar
Mine started doing it a few weeks ago too... never runs while car is off, but turns on much more often, especially while idling.
I guess it's not a bad thing since the engine will be cooler, but it's kinda annoying when you can hear the fan over the ruble of my exhaust.
Old Dec 19, 2007 | 12:37 AM
Cow town racer's Avatar
It's a bad thing, it means the relay module isn't working properly. This could possibly be disastrous if it didn't work when it should. And considering your in such a hot climate I would definately get it fixed, especially when it's cheap to do so!
Old Dec 19, 2007 | 05:39 AM
Ryan_VRX06's Avatar
bump on the 'free replacement of fan control module' - happened to me and many here. Immediately solved the problem almost 2 years ago and no probs since.
Old Dec 19, 2007 | 06:37 AM
Eclipse2Lancer's Avatar
https://www.evolutionm.net/forums/sh...8&postcount=14
There is the P/N. You're welcome.
It's a 5 minute install if you just buy the part and do it yourself (that is if you are beyond your 3/36 warranty).
Old Dec 22, 2007 | 04:17 PM
reTro's Avatar
Fine, I'll replace it!!!
Old Jun 6, 2014 | 11:00 AM
jc85's Avatar
7 year bump!
I have to replace the fan control module with my evo 9. Is this part number compatible with my car?
Old Jun 6, 2014 | 03:18 PM
347-dis's Avatar
they both should have part numbers on them. or if you got both vin numbers for both evo 9 and the ralliart ring your dealer they will be able to tell you
Old Jun 6, 2014 | 11:23 PM
CrAnSwIcK's Avatar
Originally Posted by jc85
7 year bump!
BURN HIM!!!!
1355A126 is yours, 1355A124 is ours...random revive dude, download ASA
evotris
29
Sep 8, 2013 07:26 AM
5LEEPERISAH23I
Nov 2, 2010 08:39 PM
5LEEPERISAH23I
Jul 14, 2010 04:52 AM
travail
Jul 17, 2009 10:23 AM
