Fuel Mileage
Fuel Mileage
I have 5,500 Kms on it now and am maxing out at about 350 Kms ( 90% ) street driving. I am just wondering if this about average for the car. Do you guys think the mail in from AMS would with increase the gas mileage significantly? ( excluding the boost pill) .... ( the obvious being power and torque) If so do you think the leaner settings ( which I hear the mail in does) will make my RA run too hot during the summer months.
For sure the car right now runs rich...that I have heard all over the forums and its backed up with its less than average mpg.
Last but not least, is it going to be an issue with in the event of a service or check up with the car for warranty purposes. ( I am thinking yes....but the other option is that I send the ecu back for resetting to AMS) in the event.....
Just wanted your opinions on this.
Thanks
Thanks
https://www.evolutionm.net/forums/20...les-empty.html
this thread should give you an idea.
Also guys have noticed that they get worse mileage if they run fuel with ethanol in it.
Alot of the higher octane fuel here in canada (could be states too I'm not sure) obtains its high octane rating from up to 15% ethanol additive, I'm not talking about E85 or anything like that.
I got ya. We got 10% ethonal here in Texas. Had it also out in Delaware. I've heard of some places going as high as 20% in the states, but can't remember where. While in Delaware I could;ve swore that they increased the ethanol percentage during the winter also. All around the ethonal eats a little at your mileage.
Steer clear of high-ethanol fuel unless it's bitterly cold (potentially better starting when the temp's down in the vicinity of -40, due to less issues with frozen water). Ethanol has about half the energy content of gasoline per litre (or gallon), so when your fuel is 15% ethanol, the same tank of fuel will only take you about 93% as far. That's not a good thing in a Ralliart, which has limited enough mileage to start with (plus it means you're spending about 8% more than you think you are for fuel, since it's poorer fuel, energy-wise). E85 fuel is far more appalling, in terms of mileage, but I didn't think that the Ralliart was rated for E85.
Thanks
Thanks
The Ralliart is rated at 12.2 L/100km for city. Assuming you are filling up with 45L you are getting 45L/3.5= 12.86L/100km so not too far off from the rating.
It is too bad the economy meter resets itself to 0 after 4 hours, otherwise you'd have an indicator of what you got per tank.
The reflash should give you better gas mileage. It's pretty tough to keep it at above 20mpg.
You can't boost and drive in vacuum. It's also tougher because this turbo spools instantly.
You could always ask a tuner to tune your car for a more mileage-favorable A/F ratio rather than a max-performance tune. Ask them to make it around 11 to 11.5:1 rather than the stock 9:1 and you'll get better mileage out of the car, if that's what you are going for.
zboost
Apr 10, 2014 07:44 PM
