Considering a 2010 Ralliart or 2010 WRX
Old Dec 15, 2009 | 10:27 AM
  #166
boondoc's Avatar
Conyo!!! How much power are you pushing? I thought those things ran double that stock?
Old Dec 15, 2009 | 10:34 AM
  #167
PCToolsWiki's Avatar
Around 350 at the wheels.
Old Dec 15, 2009 | 10:38 AM
  #168
ambystom01's Avatar
Getting that kind of power in a RA or WRX won't be cheap and you're fuel mileage with likely be even worse than 10 MPG.
  #169
Methodical4u's Avatar
to get 10 mpg how do you drive?
Old Dec 15, 2009 | 10:41 AM
  #170
Mildly aggressive most of the time. It is hard not to go fast when you have that much power.
Like I said previously I don't plan on modding the RA.
Old Dec 15, 2009 | 10:42 AM
  #171
chino ali's Avatar
what are you talking about?
his gas mileage will be exceptionally better with a 350hp RA.
Old Dec 15, 2009 | 10:45 AM
  #172
ambystom01's Avatar
Yeah AWD turbo cars increase in fuel efficiency as you mod them.
Old Dec 15, 2009 | 10:46 AM
  #173
chino ali's Avatar
of course they do.
lol
Old Dec 15, 2009 | 10:55 AM
  #174
boondoc's Avatar
Wow u drive aggressive for that but the power is addicting. Well either way u go your gas mileage will be a hell of a lot better. Let us know how your test drive goes.
Old Dec 15, 2009 | 11:07 AM
  #175
HiBoost gets 30 mpg highway with a highly modded X that is running low to high 11's.
Old Dec 15, 2009 | 11:10 AM
  #176
chino ali's Avatar
really?
  #177
ambystom01's Avatar
Do you have a link?
Old Dec 15, 2009 | 11:14 AM
  #178
tipoytm's Avatar
Eh, it all depends on how you drive. I have a gas guzzling X supposedly gets 16/22 city/highway EPA. I average 19 city and 25 highway with just a tune (normal driving habits, minimal boosts).
edit: I use a milder version of Hiboost's cruise mod which should be applicable on RAs too. You won't get 30MPG on it though, unless you have a highly modded setup like Hiboost's that provides better breathing on the powertrain.
Old Dec 15, 2009 | 11:16 AM
  #179
UT_Evo's Avatar
10 mpg in a 350 whp fwd car that doesn't weigh too much? That seems odd to me. You'll get way better than that in a stock WRX or RA.
I did gain about 1-2 mpg when I got a tune and a TBE on the Evo... But anything past that and it is definitely going to go downhill. I didn't gain much, but didn't lose any with the Subaru, but that was just a mild tune.
30 mpg on a heavily tuned Evo seems crazy, unless he's dropped the weight and/or has something else going on (turns off boost on the freeway, runs an economy map, etc). "Highly" modded could mean 2700 lbs... that'd probably give a pretty huge increase in gas mileage
Old Dec 15, 2009 | 11:26 AM
  #180
UT_Evo's Avatar
Originally Posted by Ladogaboy
If all you care about is straight-line performance, then, technically, the WRX is far superior to all of the other cars mentioned, including the STi and EVO.
Why do you say this? Last I checked the Evo and STi both do 0-60 in the sub 5 second range. The WRX265 is 5.2.
Originally Posted by Turbodemon
i heard the wrx 09 > than 08 if u going that route.
That is because the WRX 09 has 265 hp over the old 220ish that the 08 had.
Wouldn't the SST transmission be under warranty?
Most likely, Mitsu has been much better with covering warranties, but they have had their issues in the past. And like was said, if it shows any driver abuse or moddifications, then prepare for a bigger fight. But that's true with any car company who wants to make (rather than lose) money
