Mitsu Recommended Fluids!
Old May 8, 2010 | 06:57 PM
tjac357's Avatar
Since everyone seems to be asking what fluid to use for what I thought I'd make this thread. It's in everyone's manual page 9-11 to 9-12, but now it's on here too.
Ralliart Fluids
Fuel: 14.5 gal (55.0L) 93 Octane
Engine Oil: Oil pan- 5.1 qt (4.8L) 5W-30
Filter- .32 qt ( 0.3L)
Power Steering: (As required) Genuine Mitsubishi Power Steering Fluid
TC-SST: 8.0 qt (7.6L) DiaQueen SSTF-I
Transfer Oil: .85 qt (0.8L) DiaQueen LSD Gear Oil
AWC Control Fluid: .95 pt (0.9L) Diamond ATF SP III
Rear Differential Oil: .58 qt (0.55L) DiaQueen LSD Gear Oil
Brake/Clutch: (As required) DOT3 or DOT4
Hood Lock Release mechanism and safety catch: (As required) Multipurpose Type
Grease NLGI Grade 2
Engine Coolant: 7.9 qt (7.5L) Long Life Antifreeze Coolant or equivalent
Washer Fluid: 4.3 qt (4.0L) Whatever you choose!
Refridgerant (Air Conditioning): Label under hood upper left corner. HFC-134a
Hope this helps
Old May 8, 2010 | 08:03 PM
jan_ralliart's Avatar
thx for the informations!!
it helps a lot ^^
Old May 8, 2010 | 10:53 PM
laksman91's Avatar
Fuel required is 91 Octane
Old May 9, 2010 | 02:42 AM
bacquerel's Avatar
thanks man!
Old May 9, 2010 | 08:56 AM
initial_d2k's Avatar
i think its 93 for the state since we dun have that in Can.
they wouldnt go and write 94 cuz only Petro Canada has them...
Old May 9, 2010 | 09:28 AM
tjac357's Avatar
Yea the book says 93, but you can get away with 91. Only go lower if than 91 if it's an emergency and there's nothing else.
Old Apr 17, 2011 | 07:25 PM
toredefine's Avatar
If this isn't stickied yet, it ****ing should be!
Old Apr 17, 2011 | 09:40 PM
RA173's Avatar
nice! now add when each fluid should be changed to make it even better!!!
Old Apr 19, 2011 | 04:15 AM
03chi-town0Z's Avatar
How about linked in the quick reference thread?
Also, be careful with the capacities since they are total cap. and not standard drain/fill capacities. Always measure where applicable.
I'll try to help with the replacement intervals and get some part numbers for you all too if I get some time.
chaotichoax
Jun 8, 2020 06:10 AM
AMTrombley0924
Aug 26, 2014 04:51 PM
RussellM
MitsubishiParts.net - WA
58
Jul 16, 2013 07:25 AM
Clipse3GT
15
Jun 19, 2012 06:54 AM
pao
Jul 1, 2008 07:00 PM
