CEL then Car Acting Strange
Old Jul 9, 2013 | 05:32 AM
buddy712's Avatar
Hello, I am hoping you guys can help me. I tried to search but not sure exactly what to search on this one.
I was on my way to work this morning, as I was getting on the express way I gave the ralliart some gas. As I passed about 5200RPM the CEL came on. After that the car has been shifting crazy hard when at part throttle and seams like there is little to no boost above 4K RPM. I'm at work and have not had a chance to read the code yet. Anyone ever have this issue or any ideas what is going on? Thanks in advance for all your help
Old Jul 9, 2013 | 05:46 AM
Veronica's Avatar
The computer will go into a 'limp mode' to get you home. Have the code read (tell us what it is) and cleared (and see if it comes back).
My tranny shift fork #2 kicked a code and the tranny went into limp mode (gears 2/4/6 only...) reset and has not come back after atleast 4K miles...
Old Jul 9, 2013 | 05:56 AM
buddy712's Avatar
Thanks for the reply. I am going to try and have the code read during lunch today. Will let you know. Thanks again
Old Jul 9, 2013 | 03:28 PM
buddy712's Avatar
Got the code read. It was a P0102 (MAP voltage low). Going to check everything now.
Old Jul 10, 2013 | 05:39 AM
Veronica's Avatar
Check the wiring and then change the sensor.
Old Jul 10, 2013 | 07:31 AM
crak's Avatar
the MAP is the mass airflow sensor. IT will be located right after the intake filter. Thats your culprit!
Old Jul 11, 2013 | 05:11 AM
Veronica's Avatar
^negative.
MAP is Manifold Absolute Pressure (vacuum (or boost ). MAF is Mass Air Flow Sensor (incoming air volume)...
Old Jul 12, 2013 | 08:16 AM
crak's Avatar
ah crap, what was i thinking. thanks for the correction.
Old Jul 20, 2013 | 06:30 AM
PistenBoy's Avatar
Did you end up solving your issue? Boost leak? BPV Leak?
rjsdxm
Jan 27, 2015 07:57 PM
barrman
Oct 23, 2012 05:48 PM
Knguyen228
14
Sep 29, 2008 03:41 PM
byc_panty
Nov 30, 2007 11:37 AM
supersupra
11
Sep 12, 2006 08:08 PM
