Engine Knock?
Old Sep 25, 2011 | 08:14 AM
slicksta69's Avatar
Engine Knock?
Hello Everyone
For the last couple of months I have been hearing this pretty bad knock coming from my engine/Tranny. I took it into Mitsubishi and they informed me that these sounds are normal.
Now the ticking sound im not worried about, I know thats normal. Its the just valves and intake. It's the loud chatter in the backround I am worried about. It's very noticeable once I open the hood in the video.
Now after reading multiple threads on weird engine sounds, and multiple people are indicating its the SST tranny chattering. However I have not seen a video posted to compare the sounds.
I took a video for everyone to listen to. I would love your guys input on this.
Thank you!
http://www.youtube.com/watch?v=amXTBCSgHX8
Old Sep 25, 2011 | 08:29 AM
pool playen bob's Avatar
yeah, that doesn't sound normal.
i don't know what the sound was but a guy here locally had some work done to his car. and a brass bushing (coupler) as you'd put it went out as a part of the sst tranny. causing a rattle. does it get louder and worse under acceleration? or go inop?
Old Sep 25, 2011 | 08:33 AM
slicksta69's Avatar
I cant tell if it gets louder under acceleration. The Engine/Exhaust is to loud.. The issue is intermittent and I have not noticed a performance loss.
Yesterday when i started my car it happened, but after i drove ~50 km's parked it and started it, the sound would repeat itself.
Old Sep 25, 2011 | 09:01 AM
its defiantly not right. sounds like something came loose somewhere down the line. probably have to get a long screw driver and treat it like a stethoscope to help pin point the suggested area.
Old Sep 25, 2011 | 09:24 AM
jkennedy293's Avatar
It does sound like the clutch plates chattering, but it is a lot louder than mine. It could because you are in a parking garage.
Old Sep 25, 2011 | 09:25 AM
slicksta69's Avatar
Just as loud when its outdoors
Old Sep 25, 2011 | 10:00 AM
nismo n9ne's Avatar
try to take it to another dealer an seee what they say.
Old Sep 26, 2011 | 10:34 AM
RazorLab's Avatar
Normal.
Mods, can we sticky a damn video of this so a new thread stops coming up EVERY MONTH.
Old Sep 26, 2011 | 12:45 PM
velocityhead's Avatar
I have all of the same sounds on my car, though the sound you're concerned about sounds a bit louder in the video than I've experienced on my car.
Old Sep 26, 2011 | 12:49 PM
Slyy's Avatar
lmfao i have the same sounds and it doesn't sound healthy. Benefits of having the SST baby
Old Sep 26, 2011 | 01:03 PM
slicksta69's Avatar
Thank you everyone for your inputs. It is in fact a normal sound - If anything does happen to the tranny I will notify everyone. Dealer indicated they have everything noted.
Originally Posted by razorlab
Normal.
@RazorLab - No need to get frustrated. I hope you can understand this sound got me worried because I have had so many other issues with this car. There has already been over $10,000 of warranty repairs on my car from multiple issues. Mitsu tech bricked my ECU when I purchased the car, replaced two AWD pumps, and replaced a rear diff.
@Moderators Please do sticky one of these topics to inform everyone of the SST's clutch chatter. Thanks
Old Sep 27, 2011 | 02:49 PM
RazorLab's Avatar
I totally understand. If it was stickied it would be easier for people like you to find the information and be more assured.
Old Oct 15, 2011 | 07:33 AM
slicksta69's Avatar
@razorlab - I have done dozens of road tests and confirmed it is the SST Tranny. Sound is gone as soon as I put into drive / let go off the brake and the tranny engages.
I do have one question that no "Mitsu tech" can answer. Why do the clutches chatter like that? Has a spacer been slightly compressed causing the clutches to cause that chatter noise?
Old Oct 15, 2011 | 08:31 AM
RazorLab's Avatar
Yes and if you would have searched you would have found that exact information.
Old Oct 15, 2011 | 08:56 AM
SudzRA's Avatar
The sound you're hearing is the clutches moving around freely because they're disengaged. Once you clamp the clutches (put the car into gear) they stop moving. However, you might still hear some chattering even when you're in gear, as in any given gear you've only engaged one of your clutches. The other one remains disengaged and continues to chatter.
EvaTheEvo
Feb 6, 2016 07:04 PM
Randal
Nov 28, 2012 07:34 AM
undressesitself
Sep 9, 2012 08:48 PM
BaumBizzle
May 10, 2012 04:00 PM
BRN-EVO
20
Jun 4, 2010 06:13 PM
