How to: Upper/Lower IC pipes & EvoX Intercooler
Old Feb 29, 2012 | 07:07 PM
  #166
BravoZero's Avatar
Originally Posted by TurtleRA
Well just finished installing the LICP, and yes a bit of a challenge, however I got all 3 bolt holes to line up, which I thought would not happen. As for connecting to the BOV, I had the full bov tubing from an evo x that the guy also gave to me when I bought it. Well I took that tubing and cut in in half and used the end that had the s or z form to it. This worked perfect and did not have to use a piece of pipe. So if anyone is buying a licp, try to get one with the evo x bov tubing. Plus it looks completely OEM, which is also nice.
I thought about doing that, but the cost offset of buying a used BPV tube from a X compared to a $3 pipe from Home Depot is what prevented me from doing so. As long as the piping is thick and strong enough, and you have it tightened down well, you won't have any problems.
But that's not a bad idea for anyone doing this in the future, good work!
Old Mar 1, 2012 | 06:55 AM
  #167
crak's Avatar
Called around town and found a guy who does CNC and he cut me a tube. nice guy too.
Old Mar 3, 2012 | 06:21 PM
  #168
pepsi_merch's Avatar
Sooo you NEED the 6 inch pipe IF you want to put the stock snorkel on right? Cuz i have a cai, and i dont mind that the bpv is all crooked. Thanks in advance
Old Mar 3, 2012 | 07:18 PM
  #169
BravoZero's Avatar
It won't look pretty but if it saves you money and you don't need the snorkel, go for it.
Old Mar 4, 2012 | 01:29 PM
  #170
hotkupa's Avatar
If any one who did the swap and not need anymore the short zigzag plastic pipe that connects the licp to BOV pipe would consider selling it I would really appriciate.
Old Mar 5, 2012 | 06:26 AM
  #171
Thanks homie, the 2 or 3 dollars im saving isnt at the top of my reasons list, what really is is the fitment and making sure it wont blow off under pressure etc.... Maybe ill do the radiator hose like someone said. Just take the bpv to get the correct measurement (diameter) and correct length (6 inches right?) autozone sells these radiator hoses right? Or where can i get it?
Old Mar 5, 2012 | 07:07 AM
  #172
BravoZero's Avatar
Unless you're hitting into the 30+ psi range, as long as its nice and snug, the hoses won't blow off.
The radiator hose idea will work great if you can find one and trim it down to size.
Old Mar 5, 2012 | 07:01 PM
  #173
Griffin5's Avatar
Originally Posted by velocityhead
HELP HELP
I'm installing the Ultimate Racing LICP up to an Evo X style FMIC right now and have run into a little snag...
The bend in the LICP is hitting the front bar of the car body. You can see where this would occur by looking at the dimple that is moulded into the black plastic RA stock LICP pictured above. That dimple obviously avoids this problem but for those of you that have said the UR LICP fits perfectly, how did you get around this?
Old Mar 6, 2012 | 05:09 AM
  #174
BravoZero's Avatar
Originally Posted by Griffin5
HELP HELP
Did you order the RA-specific or Evo-specific LICP?
Readjust some stuff, it will fit.
Old Mar 6, 2012 | 05:44 AM
  #175
Griffin5's Avatar
Hi BravoZero, it's definitely the RA specific LICP kit.
The pipe is on there, its just rubbing against the front bar which is not ideal. My local shop is doing the install as they're doing a lot of parts at the same time. I have to trust his advice on the fitment issue. Just wondering if any one else has experienced the same thing and how they over came it.
Old Mar 6, 2012 | 06:22 AM
  #176
BravoZero's Avatar
The OEM pipe from the X fits perfectly with plenty of clearance, so it might be a defective part or the shop doesn't know what they're doing.
Old Mar 6, 2012 | 06:36 AM
  #177
Griffin5's Avatar
I'll ask them to test fit a stock Evo X LICP and see if there's a difference. Thanks for the feedback
Old Apr 25, 2012 | 09:17 AM
  #178
AvenGerMK's Avatar
Originally Posted by Krimsin
thanks! yea the battery issue is temporary till I order the AMS Intake and Small Battery Kit. I'll be moving to Georgia in December and looking to get the car tuned properly down there. thanks again for this write up!
Why order a smaller battery? Just get the optima red top for your specific lancer. That's what I did and everything fits perfectly. I took off that stupid intake snorkel. Such a waste. Didn't even do anything for my SRI.
Old Apr 27, 2012 | 04:43 PM
  #179
richardjh's Avatar
Yes, mine did exactly this. I was faced with two options:
(1) Remove the extra bar that was in the way. Not a great option, but most of the pics I've seen of peoples' installs are missing this bar. It's apparently an NVH-reducing item.
(2) Getting out my precision tool (hammer) and revising the design of the LICP. Whacketty whack whack. Add the same "dimple" to the Evo X LICP that is moulded into the RA pipe.
I chose option (2). Whacketty whack!
Rich
Old Apr 30, 2012 | 05:43 AM
  #180
03chi-town0Z's Avatar
Isn't that kind of defeating the purpose...
