Request: Installing boost gauge
Old Jul 3, 2011 | 11:43 PM
pbassist12's Avatar
Im looking to buy a boost gauge and install it myself, just wondering if there is any write up or if someone could make one with pics, that would be great! Im also planning on putting the gauge in the middle above the radio, I saw that one evo had his wiring running into the A/C vent so if anyone could explain that, that would be great!
Old Jul 4, 2011 | 05:21 AM
speedie's Avatar
pillar pod would look tidier, Also look at an electric gauge rather than mechanical. There is a how to in the Evo section which is quite good.
https://www.evolutionm.net/forums/ev...lean-hell.html
Old Jul 4, 2011 | 08:18 AM
pbassist12's Avatar
yeah im not into the pillar pod tho. Thats why i wanna put it in the middle
Old Jul 5, 2011 | 06:01 PM
Mad_SB's Avatar
I promise if you go to the advanced search box and search for "boost gauge" with the options on "title only" and the section set to "EvoX How-To / Installations" you will get at least 15 threads as a result.
Search is your friend
Old Jul 6, 2011 | 12:09 AM
pbassist12's Avatar
I know i saw the threads, Im just wondering how i would run the wires from the middle of the car to the engine bay.
Old Jul 6, 2011 | 12:25 AM
pbassist12's Avatar
I kind of what to install it like this or above the radio in the middle of the car like a gps would be or something
Old Jul 6, 2011 | 07:03 AM
roversix's Avatar
^Just used the link that speedie posted... firewall is a PITA, especially with the short wires that AEM provided. But here's how mine ended up:
as you can see... my wires are highly visible... super bootleg version. Got a annoyed at one point and said forget the cleanliness.
Credit goes to OMEGIS who helped with PM'd directions.
Good luck!
Old Jul 6, 2011 | 09:20 AM
pbassist12's Avatar
thanks! Im a big fan of images cause im a visual person so its always a plus
Old Jul 6, 2011 | 10:41 AM
omegis's Avatar
Glad I could help
Old Jul 6, 2011 | 12:52 PM
pbassist12's Avatar
Any other methods of installing?
Old Jul 7, 2011 | 04:32 AM
speedie's Avatar
Not sure about the US versions but in Aus we have a grommet in the firewall in the corner behind the airbox, feeds out to above our fuse box. I have most of my wires going through it and the 0 gauge for the battery relocation
Old Jul 7, 2011 | 04:48 AM
Mad_SB's Avatar
Amongst all the search results you will find ALL the methods of getting wires from the cabin into the engine bay.. choose the shortest route that is easiest for you. As for where you mount.... that's up to you... if there is no clear path to route wiring you will have to drill holes... simple as that.
fastbu
18
Jul 24, 2012 08:39 PM
pignosesr
Dec 18, 2011 04:56 AM
rayman0690
Jun 22, 2010 07:25 PM
TK40
Feb 17, 2010 01:14 PM
Spish
May 25, 2008 07:22 PM
