Let's see your fully tuned timing maps
Old Feb 26, 2012 | 10:10 PM
  #1471
chetrickerman's Avatar
Veteran: Army
Yup. Good start
Old Feb 27, 2012 | 06:02 AM
  #1472
Raptord's Avatar
Don't forget to fix your fuel map after you rescale timing, since they use the same axis'
Old Feb 27, 2012 | 09:55 AM
  #1473
CRONZ305's Avatar
i have a new wgdc table im working on so once i get that dialed in ill work on fuel...
Old Mar 1, 2012 | 11:56 AM
  #1474
nytalonTSi's Avatar
Heres mine last messed with it in September.
Mods in sig, on 93. 24psi.
Old Mar 1, 2012 | 12:27 PM
  #1475
Veteran: Army
It needs some cleaning up
Old Mar 1, 2012 | 02:01 PM
  #1476
nytalonTSi's Avatar
I'm still learning lol.
Old Mar 1, 2012 | 02:15 PM
  #1477
Veteran: Army
No worries.
Old Mar 1, 2012 | 02:29 PM
  #1478
211Ratsbud's Avatar
His map definitely needs a lot of work.
I try to enter logical and conservative numbers in the areas that even you dont hit at low load high rpm, and areas you would hit if the boost were starting to increase a little beyond normal. in my case being SD my load is a little different than others, but I have 50 load head room beyond my max boost ~32 psi
Attached Thumbnails Let's see your fully tuned timing maps-timing-map-idea.png
Old Mar 8, 2012 | 10:23 PM
  #1479
jedibow's Avatar
View timing map in version 1.43
okay so really stupid question but I see many of you are able to see your 3d graphs even with the tepha bigmaps. When I view mt 3d graphs on the side they are out of scale and tiny, how do you make them viewable? I can't find a setting in ecuflash, I was wondering if it is a windows setting? I'm using windows 7.
Thank you for your help!
Old Mar 9, 2012 | 12:31 AM
  #1480
dimacoupe's Avatar
+1 same problem
Old Mar 9, 2012 | 06:11 AM
  #1481
Raptord's Avatar
In Tephra 1.43+ the combined width of the table + the 3d graph will not exceed your screen resolution. In versions prior to 1.43, it can (which means you just need to drag the table to the left to be able to see the graph fully). So if your screen resolution is too small, that's probably why.
Old Mar 9, 2012 | 11:54 AM
  #1482
jedibow's Avatar
So should I lower my screen resolution?
Thank you Raptord!
Old Mar 9, 2012 | 12:08 PM
  #1483
Raptord's Avatar
No, it needs to be bigger for the table + graph to fit.
Old Mar 9, 2012 | 12:32 PM
  #1484
211Ratsbud's Avatar
How does the overall smoothness/trends look for my map that I posted above? I have hks272, o2 dump, tbe catless, hta71, 3dsd, peaks at 350% drops to about 275% or 14* timing. 3* peak, 93 oct My timing map is tested to 390 load or something like ~30ish maybe a touch more.
Old Apr 9, 2012 | 10:19 AM
  #1485
killerpenguin21's Avatar
back from the dead, its that time of year again.
anybody ever tune a car back to back with the only change being a hi flow cat? i added a berk cat to meet lime rock noise restrictions (and help keep my own sanity). i logged the car finally yesterday, and all of a sudden im knocking above 6k where i never used to, or if i did it was 2-3 counts less.
this is the map i made after the logs to try and clean it up. car seems to want about 8-9 degrees at 6k. does that seem right for a basic bolt ons car at 24psi peak falling to 20psi? my map seems kinda soft to me.
for reference, since addition of the cat, i run right up the 240 load column, which is down a little from the test pipe setup. so im wondering if its a cse of interpolating off one more column to the left, or is this possible a lesson in back pressure and tuning?
