PATCH: TephraMod V5
Old May 4, 2008 | 09:38 PM
  #541
tephra's Avatar
just regarding the Load NTLS threshold:
What sort of load are people seeing when they downshift blip?
I am trying to fix this bug now
Old May 5, 2008 | 05:46 AM
  #542
jcsbanks's Avatar
Dave, tried to send you DMA version of V5 for your ECU but your email is bouncing attachments.
www.banks.myzen.co.uk/88580014.zip contains the public V5 you posted for your ECU, modified with DMA patches. I also attach a new xml which just has the alt inj scaling moved as previously discussed.
The exe and three xml files are the PC app. Source available if you wish.
If I've made no mistakes then the engine should start and log normally using
Evoscan etc. It should also log using my app and also be able to live map
the RAM/alt maps.
Let me know how you get on.
138 - DMA end interrupt vector
32c - transmit end interrupt vector
48800 - setup DMA
48900,48a20 - DMA end and transmit end interrupt handlers
47f00 - DMA timeout routine
47f80 - cold reset routine - copy ROM to RAM
There are a few NOPs and cmp/variable changes in the IO routines as well
that I haven't listed.
Old May 5, 2008 | 05:55 AM
  #543
tephra's Avatar
really?
thats weird - can you forward the bounce?
Old May 5, 2008 | 06:08 AM
  #544
jcsbanks's Avatar
Edited the last post with a link so you can download. Bounce forwarded.
Old May 5, 2008 | 04:22 PM
  #545
tephra's Avatar
thanks - ill have a proper look at this next week
not sure why it bounced, maybe gmail dudes are breaking stuff
Old May 5, 2008 | 08:51 PM
  #546
ant_turbo's Avatar
Hey question here do I copy and paste any of my fuel/Ignition to the
Tephra Mod Options /Alternate Hi Octane Fuel Map/Alternate Lo Octane Fuel Map
and ,Alternate Hi Octane Ignition Map #123/Alternate Lo Octane Ignition Map #123 In the Tephra Mod Options....
Or just leave them as they are....
Old May 5, 2008 | 09:25 PM
  #547
tephra's Avatar
are you going to use altmaps?
if not - disable it (ie set to 0) and then leave the fuel/ign/boost maps as is..
Old May 5, 2008 | 09:59 PM
  #548
ant_turbo's Avatar
No I won't be using the altmaps.... In new mods paych
Old May 6, 2008 | 01:55 PM
  #549
dawnduran's Avatar
Hey Tephra.
Does your moddified maps include the 2-byte-Load-Mod?!
Its important to get the answer.
Thank you
Old May 6, 2008 | 04:17 PM
  #550
Pd1's Avatar
Pd1
Originally Posted by dawnduran
Hey Tephra.
Thank you
No.
Old May 6, 2008 | 04:40 PM
  #551
tephra's Avatar
nope...
why?
Old May 6, 2008 | 05:29 PM
  #552
20psiMR's Avatar
Because its an xml mod, not a rom mod. Just add the code to your .xml file for your romID and call it a day.
Old May 6, 2008 | 05:54 PM
  #553
mrfred's Avatar
Fundamentally, its a ROM mod and not an xml mod. Yes some code has to be added to the xml file, but its only to facilitate changing the ROM.
Old May 7, 2008 | 09:03 AM
  #554
scheides's Avatar
EvoM Moderator
Note: if you are using this with mrfred's direct boost control mod, simply change boost table #3 from this:
<table name="Baseline Boost #3 (BCLS)" category="Turbo" (ecu specific form here out)
to this:
<table name="Alternate Boost" category="Mods"
Old May 7, 2008 | 09:13 AM
  #555
TouringBubble's Avatar
I can't wait to assemble and install my harness and get this map switching patch on my v15 car. No more lugging the notebook to the track ... sweet! I'm also looking forward to the 2-stage knock light.
If I haven't said it enough, thanks again fr all of the work you guys put in to this.
