Cobb Tuning Access Port Is Now Available For The Evo X!
Old Dec 3, 2008 | 10:15 AM
  #151
DynoFlash's Avatar
When they release the former street tuner for this it will be called the "race" tuner. I believe it will be 100% free.
That application will enable you to make adjustments and tune it yourself - however - be advised if you are not familar with tuning and do not have the right equipment e.g. wideband etc. then you may be better off to get a pro tuner to set up the maps for you.
Al
Old Dec 3, 2008 | 10:18 AM
  #152
Dosagex's Avatar
^have you tuned with the AP yet? if so how is it?
Old Dec 3, 2008 | 10:23 AM
  #153
DynoFlash's Avatar
It tunes the same as any other tuning tool - like ecutek etc - they all adjust the same stock parameters in the stock ecu
The difference is the customer features are enhanced on the AP- the ability to save and upload maps and all the gauges and other features are only available on the cobb
Al
Old Dec 3, 2008 | 10:40 AM
  #154
Papi4baby's Avatar
Thanks for the answer Al.
Old Dec 3, 2008 | 10:43 AM
  #155
Gsxtremedsm's Avatar
Al when will you get these in? I will have a test pipe back exhaust, nisei IC piping and a drop in filter, will you be able to set up a tune for me if I order an AP from you?
Are you able to control the boost good enough or should I do a manual boost controller as well?
Old Dec 3, 2008 | 10:50 AM
  #156
dcasandman's Avatar
^Ive always heard cobbs off shelf maps are pretty conservative so Im sure be able to get more out of the car.
Old Dec 3, 2008 | 11:05 AM
  #157
evo_Eks's Avatar
if i have a custom tune and decide to buy this, would i be able to save my custom tune in my access port?
Old Dec 3, 2008 | 11:13 AM
  #158
RallySport Direct's Avatar
Silver Sponsor
Any map that is made to work on a 1000s of different cars in different areas will need to be conservative. Cobb does a good job at balancing safety and performance IMO. A custom tune will always net more power then a off the shelf map.
If your custom tune was done by a cobb certified protuner you should be able to have them convert your current map to a cobb .ptm file and then you can load it in your AP.
Old Dec 3, 2008 | 12:06 PM
  #159
JuniorAWD's Avatar
Results on a bone stock car with just the stage 1 base flash
Old Dec 3, 2008 | 12:09 PM
  #160
Silver Sponsor
NICE!! I really like how it smoothed out the curve you can tell the car is alot happier with the AP
Old Dec 3, 2008 | 01:03 PM
  #161
Papi4baby's Avatar
Thank you sir.
Oh yeah, the engine does feel alot smoother and more linear now. You have the big spike at about 3k and after that is nice and progressive till red line.
Old Dec 3, 2008 | 01:22 PM
  #162
Weezheat's Avatar
How do the maps work if you already have some aftermarket parts? For example, an Exhaust from a non-COBB brand and an intake?
Old Dec 3, 2008 | 01:31 PM
  #163
Silver Sponsor
The intake no. The exhaust you should be able to run with the stg 2 but we will not know for sure until the map is released
Old Dec 3, 2008 | 02:00 PM
  #164
tofumann's Avatar
you guys have any units left. I am currently oversea and wont be back for couple of wks
Old Dec 3, 2008 | 02:07 PM
  #165
Silver Sponsor
Yeah we just got another batch today from cobb we should have plenty of them for a while
