5 speed into MR swap thread!
Old Apr 14, 2009 | 02:48 PM
PeteyTurbo's Avatar
Exclamation 5 speed into MR swap thread!
So I have the swap 99% completed.. I want to make this thread for future refrence for members planning on this swap since there is a bit of lack of info and I have found a few things not covered..These are the parts you will need, if someone can scource part numbers I will edit this list to reflect them..
Parts needed:
1. 5 speed transmission
2. 5 speed shifter base with shifter
3. 5 speed shifter cables
4. Washers for the 5 speed cables and linkage. ( the MR has ONE washer you can use, you will need to order another for the trans. side linkage)
5. Retaining pins for shift cable linkage. ( you need 3 total, one for the shifter connection and two for trans linkage connection.) You can re-use the ONE pin you have from the 6 speed, but you will need 2 more total..
6. Upper transmission mount for 5 speed
7. 5-speed clutch line. You can re-use the 6 speed line but you will have to bend it significantly to get it to fit/work.
8. 5-speed clutch line support. This holds the hard clutch line in place with a clip. You can also cut off the extra metal from the 6 speed unti to get it to work.
9. 5-speed shifter cable support for transmission, if not included with transmission.
10. 5-speed wire harness for speedometer and reverse switch.
This is everything needed to do the swap. You can use the MR shift knob on the 5 speed shifter..
Hope this helps
Again if anyone has part numbers for these parts it would fully complete this post
Old Apr 14, 2009 | 03:17 PM
BoostLover99's Avatar
This is good info - thank you for posting it!
Old Apr 14, 2009 | 03:20 PM
jjm4life's Avatar
pete you slacker. if you were really trying to help your former 6speed brethren you would have part numbers. parts numbers or ban!
Old Apr 14, 2009 | 03:23 PM
shuttlegoose's Avatar
i too agree, good write up, but you are slacking a bit petey, get your game up.
Old Apr 14, 2009 | 03:27 PM
GST Motorsports's Avatar
I'll map all the part #'s for you tonight.
I'm surprised it took this long for a list like this to pop up.
You also need the 5spd shifter bezel unless you want to modify your 6spd one.
Old Apr 14, 2009 | 03:36 PM
jjm4life's Avatar
^^ way to step up gst. thats pete your for, just never follows through. quite a shame really
Old Apr 14, 2009 | 03:40 PM
PeteyTurbo's Avatar
My 6 speed one fits fine, although I heave heard it can pop out out or something.. I dont see any clearance issues but it was rubbing the shifter mount a little..
Don't you have an evo to break?
Old Apr 14, 2009 | 03:42 PM
jjm4life's Avatar
yea, something should be popping off it sooner or later. you know you'll be the first person i call. be waiting by the phone
Old Apr 14, 2009 | 05:11 PM
05ah8james's Avatar
Damn, I didn't know I needed all this! I have the shifter cables, shifter assembly, and trans ligned up... crap...
Old Apr 14, 2009 | 05:16 PM
silver9mr's Avatar
thanks man thats a great help for people like me who thought all it was just a swap and you good i would have never thought about all the small things lol
Old Apr 14, 2009 | 05:20 PM
leecho's Avatar
This is awesome, and should be a sticky when it's done.
If my 6-speed ever gives up, I might need to consider a swap.
Old Apr 14, 2009 | 07:44 PM
Raceghost's Avatar
What about going the other way, or partially. Great write up. I am curious about an MR ACD going into an 8....
I have an eight, but want ACD.
Old Apr 14, 2009 | 08:17 PM
PeteyTurbo's Avatar
You will need the ECU and wire harness for that to work, as well as acd pump, lines, and T-case...$$$$$$
I will write a list for going the other way also
Old Apr 14, 2009 | 11:41 PM
MN168658
MN107671XB Knob,gearshift Lever
MN168249 Lever,gearshift
MF450154 Washer
MF450405 Washer
MF445004 Nut,gearshift Linkage
MF103142 Bolt,gearshift Linkage
MF450153 Washer,gearshift x2
MR232147 Bushing,gearshift x2
MS240147 Bolt x4
MB870574 Spacer x4
MR103559 Bushing x4
MR246297 Bracket,gearshift
MN107670 Cable,gearshift
MB175244 Washer,gearshift
MF450404 Washer,gearshift
MF451107 Washer,gearshift
MB180001 Washer,gearshift
MB829013 Bushing,gearshift
MB844379 Pin,gearshift Linkage x2
MF472038 Pin,gearshift Linkage
MR491558 Bracket,t/m Mount
MD770358 Tube,clutch Release
MD770815 Bracket,m/t Clutc
MR980787 Bracket,m/t Gears
need to see a photo of this
Old Apr 14, 2009 | 11:57 PM
Raceghost's Avatar
Thank you.
We can take that offline if needed, or open another post...
These should be stickys.
