need Evo 9 owner to test rear O2 *heater* sim patch
Old Apr 18, 2009 | 09:02 AM
  #211
SLO-EVO's Avatar
BUMP for the patch becoming availabe!!!
Old Apr 19, 2009 | 09:30 AM
  #212
EVIL_EV0's Avatar
Does this patch work on roms previous to 5.10? I'm running one with valet but not with map switching. I would like to completely remove the rear O2.
Old Apr 20, 2009 | 05:15 PM
  #213
japanevo's Avatar
i see a lot of talk about 0031, does this patch get rid of 0141 also???? i used the instructions on page 9 for 9653 and i still get P0141.
Old Apr 26, 2009 | 01:52 PM
  #214
StreetEvo's Avatar
Mr.Fred / Tephra, have either of you had a chance to look into the heater circuit patch for 94170015?
Old Apr 27, 2009 | 06:16 PM
  #215
Wiznaz's Avatar
This thread has made my head spin. Is Acamus' code from #117 insufficient for the 88590015 ROM?
Old Apr 27, 2009 | 09:13 PM
  #216
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
For removing CEL it is insufficient, apply mrfred's patch also.
Old Apr 28, 2009 | 05:33 AM
  #217
japanevo's Avatar
so i need a patched rom then... the way i read it, i thought this first part was the patch.... and then you make the changes indicated.
<table name="Non-Continuous Monitor Availability Patch Part 1" category="OBD Inspection" address="34C4E" type="1D" level="1" scaling="Hex16"/>
<table name="Non-Continuous Monitor Availability Patch Part 2" category="OBD Inspection" address="34CCE" type="1D" level="1" scaling="Hex16"/>
<table name="Non-Continuous Monitor Completion Patch" category="OBD Inspection" address="34CD4" type="2D" level="1" scaling="Hex16">
<table type="Static Y Axis" elements="2">
<data>34CD4</data>
<data>34CD6</data>
</table>
</table>
Old Apr 28, 2009 | 02:44 PM
  #218
Wiznaz's Avatar
If I'm not mistaken, follow MrFred in post 59:
https://www.evolutionm.net/forums/6691277-post59.html
And then follow Acamus in post 117:
https://www.evolutionm.net/forums/6727392-post117.html
I haven't attempted this yet and not even sure what order it needs to be done in. If someone else can confirm, it'd be appreciated. Inspection is up in 2 days. (I should just put my O2 back in.)
Old Apr 28, 2009 | 05:49 PM
  #219
japanevo's Avatar
i am starting to get that impression but those links are for 88590015, i am using 96530006 which is in post 135. so i guess my next question is...
does anyone have a patched 96530006 ROM?
Old Apr 29, 2009 | 09:08 AM
  #220
diiirk@AwdMotorsports's Avatar
sooo, whats the patch for 88590015?
Old Apr 29, 2009 | 10:14 AM
  #221
fostytou's Avatar
EvoM Community Team
RTFT?
https://www.evolutionm.net/forums/6820569-post184.html
https://www.evolutionm.net/forums/6811116-post182.html
https://www.evolutionm.net/forums/6997439-post219.html
Old May 5, 2009 | 08:49 PM
  #222
Jeff_Jeske's Avatar
Okay.... do we have to use the rom posted or does this work with existing roms?
The reason I ask is somewhere in this thread someone stated it will work with 5.10.
Old May 6, 2009 | 06:13 AM
  #223
travman's Avatar
No - just copy the definitions into the ecuflash xml, then open your rom and copy the values from mrfreds rom to your rom with the new tables.
Old May 6, 2009 | 06:31 AM
  #224
Jeff_Jeske's Avatar
Dangit... that's what I did and I still flag a CEL after I remove the O2.
The only change is I copied the values from #117.
I modded the XML with the junk in 117 then modified the values with what is shown in 117.
Do I really need anything that Mrfred posted?
Old May 6, 2009 | 08:39 AM
  #225
fostytou's Avatar
EvoM Community Team
yeahhhh, check post 59.
