Evo 8 ECU Swap Works!!!
Old Jan 29, 2010 | 03:32 PM
  #196
JRR's Avatar
JRR
ok so i have the 1.3b cable and went back to v1.29a of ecu flash and i keep getting the error:
any ideas? and also does anyone have a GOOD version of 1.42 because i keep getting errors from downloading it from the openecu site.
josh
Old Jan 29, 2010 | 04:58 PM
  #197
senate6268's Avatar
You got PM.
Old Jan 30, 2010 | 10:48 PM
  #198
JRR's Avatar
JRR
got it. do you have to swap pins 8 and 22 to get it to read the rom or can you just leave the pins as is in the connector and read it that way?
josh
Old Jan 31, 2010 | 12:07 AM
  #199
03lances's Avatar
Ok senate so whats up with the annoying P0069 code that pops up everytime I flash my evo ecu any way to get rid of that?
Old Jan 31, 2010 | 03:07 PM
  #200
JRR's Avatar
JRR
ok so i got it to read the rom finally. whats he best program to use to edit the .xml file?
josh
Old Jan 31, 2010 | 03:27 PM
  #201
senate6268's Avatar
The P0069 code is typically an indication of a bad MAF or bad MAP sensor. You can disable it via the periphery bits. However disabling it wouldn't be a good idea if there is actually a problem with one sensor or the other.
  #202
03lances's Avatar
Microsoft wordpad works great for me
Old Jan 31, 2010 | 03:28 PM
  #203
senate6268's Avatar
josh
I use Notepad++, but any basic code editor would serve the same purpose.
Old Jan 31, 2010 | 04:01 PM
  #204
03lances's Avatar
Oh crap don't know why I was thinking the cel was a common problem when flashing these Ecus sorry. Crap looks like I will have to reinstall my stock ecu and see if the code trips again. If so then I will contact who I bought the maf from and tell him its a dud
Old Jan 31, 2010 | 07:09 PM
  #205
vmrevo9's Avatar
Veteran: Air Force
kinda off the wall but will the evo 8 ecu work on a 1g talon/eclispe? a buddy of mine just got his 1g n/a swapped with a turbo'd 4g63. i had mentioned using an 8 ECU but wasnt sure if it would work.
Old Jan 31, 2010 | 09:41 PM
  #206
JRR's Avatar
JRR
it should i would think. some guys have done it to the 2g eclipses.
josh
Old Feb 1, 2010 | 09:45 AM
  #207
03lances's Avatar
Ok so I have found through various tests that my ecu is what is tripping the code and all my sensors including my new maf is fine. Anyone know if the 05 evo8 has different map settings than the 03 or 04? Couldnt really find much in the ecuflash forums although not sure how to word it either.
Old Feb 1, 2010 | 03:03 PM
  #208
JRR's Avatar
JRR
plugged everything in today, flashed the ecu to the corrected settings for the injectors and the stuff senate posted on the first post here inthis thread and the car will not start? any ideas? did i miss something?
im running wrx 440's and the 399 maf from the evo.
josh
File Type: zip
Old Feb 1, 2010 | 03:08 PM
  #209
JRR's Avatar
JRR
josh
nvm i figured it out. i didnt swap pins 8 and 22.
guess thats what i get for only having 2 hours of sleep then working for another 8 and going then to work on the car.
my bad
josh
Old Feb 1, 2010 | 04:23 PM
  #210
senate6268's Avatar
Glad you got it squared away. The pin swap is critical as your fuel pump won't turn on if they aren't swapped.
