E85 Timing Maps
Old Feb 22, 2010 | 05:26 AM
  #76
mrfred's Avatar
Originally Posted by poyz
Here's my E85 timing map.
Evo 9
FIC 1050
Walbro 255L/h
LICP
Tomei dump pipe & front pipe
HKS Hi Power Silent cat back
Comments/Suggestions welcome...
Its got quite a bit more advance than my most recent timing map. My car doesn't seem to show the same gains with timing as other Evo 9s, but your map looks more aggressive than even GST Motorsports typical Evo 9 stock turbo map.
Old Feb 22, 2010 | 03:15 PM
  #77
poyz's Avatar
Thanks for the feedback.
It's only running 25 psi and tapers back to 20psi.
I've tried running more boost but I'm thinking there is a restriction. Perhaps the exhaust or the stock airbox.
Old Feb 22, 2010 | 04:02 PM
  #78
mrfred's Avatar
Even in the cells that correspond roughly to those boost levels, the timing is still pretty high. Even if there is no knock, you could well be pounding the main bearings and wrist pin bushings. How did you pick these timing values?
Old Feb 22, 2010 | 04:52 PM
  #79
poyz's Avatar
Now here's the weird thing, if I try to take timing away I see knock.
It was tuned by a local tuner about a year ago, I've just migrated to V7 and smoothed/interpolated out the map.
Old Feb 22, 2010 | 04:56 PM
  #80
buchnerj's Avatar
Mine. Mods in sig.
Old Feb 22, 2010 | 04:57 PM
  #81
Chris Moore's Avatar
Originally Posted by esevo
This is a Timing map that is being used in a customers car in phoenix. I couldn't believe it, when I got this much timing in the car with no knock. Car ran great at 620 + whp!
Mods
1450CC
Bosch 44
Full race T3
HTA3582
30 psi
2.4L
Speed Density conversion
I can't believe that is not past MBT in at least some areas. E85 is the reason you got that much timing without knock. You need to know how to tune it before jumping into it. Not trying to be a jerk, just saying. That is crazy timing for that turbo and boost level.
I agree with Aaron too, but the way you posted a log showing how there is no knock with that much timing makes me think you really don't understand what MBT is.
Old Feb 22, 2010 | 05:01 PM
  #82
mrfred's Avatar
That's strange. Not much more to say except that hopefully the person who tuned your car is aware that E85 requires a different tuning strategy than gasoline.
Old Feb 22, 2010 | 06:06 PM
  #83
lan_evo_mr9's Avatar
Originally Posted by buchnerj
Mine. Mods in sig.
You're not going over 300 load with that setup? It also seems a little rich for E85, unless that's your pump fuel map.
Old Feb 22, 2010 | 06:19 PM
  #84
I had posted a V7 map earlier in this thread and was asked if it had any knock, to which I responded no. Well, I was wrong...I'm not sure if it's the winter blend or just too aggressive (probably both). So I turned it down a notch for safety, not a whole lot, but just enough so I don't get those few counts of knock. I was only seeing 2-3 randomly, but it was enough for me to do something about it. That SES light flashing is pretty annoying . Thank you Tephra
Old Apr 13, 2010 | 12:42 AM
  #85
ValdezeEvo's Avatar
So I'm converting to E85 this week and I was playing around with my fuel maps. Without logging I understand its hard to determine what needs to be changed but I leaned it out a bit and was wondering if it was good as a starting point. Or should I wait till I am actually logging E85 and then make the changes. Let me know what you guys think, thanks.
Mods:
Fuel Pump
head studs
ported exhaust mani
Cone filter
3" tbe w/ test pipe
LICP
ebay IC
Metal DV
Old Apr 13, 2010 | 02:21 AM
  #86
mrfred's Avatar
E85 is very forgiving in terms of AFR, but I still wouldn't go WOT without tuning AFR. With that said, my personal observations on my Evo are that for AFRs richer than about 11.5:1, I tend to observe mild knock across the entire rpm range (peak of 3-4 knock counts at mid rpms), and at AFRs leaner than about 13.0:1, I would get breakup on spool and at high load on the stock ignition.
Old Apr 13, 2010 | 02:55 PM
  #87
kaymin's Avatar
What AFRs is everyone running at WOT?
Old Apr 13, 2010 | 03:42 PM
  #88
E85evo8's Avatar
right around 12:1, but always lower if anything and never really any higher WOT
Old May 7, 2010 | 11:28 AM
  #89
speifer's Avatar
Noob question: when finding MBT, how much will HP increase with each degree of timing added once your at or near MBT?
For instance, if you gain 15 hp with 1 degree added, then you only gain 5 hp by adding one more degree, are you at MBT?
Old May 8, 2010 | 05:18 AM
  #90
leecavturbo's Avatar
not bad logic imo. although mtbt is termed by torque, measuring torque will have more resolution than hp. you really need a dyno to measure right upto mtbt but for *** tuning your idea of dimishing gains seems like a good indicator to me.
