launch maps
Old Oct 5, 2011 | 09:22 AM
  #181
Raptord's Avatar
Originally Posted by kronik5383
thats crazy! i get 14psi easy on a stock turbo
a stock turbo is a bit easier to spool up than a 6765
Old Oct 5, 2011 | 07:27 PM
  #182
kronik5383's Avatar
true. what timing block do you have for the rpm? and at what rpm is it
Old Nov 20, 2011 | 07:54 AM
  #183
wizzo 8's Avatar
So if you are knocking on the 2step Im assuming this is not normal or good. I lowered my timing and it made it better but didnt go away fully. I have timing at 10. Im assuming I need to get closer to 0
Old Nov 20, 2011 | 09:13 AM
  #184
Raptord's Avatar
Sorry, I'm a bit late with my reply but I never noticed your message. At the track I don't use launch maps, just the regular 2-step at 5k because I'm on stock clutch and don't need more power as it is. Just for kicks I'm testing out launch maps at 4.5k at -10 degrees.
Try to make a smooth transition, and also keep in mind you'll be on your regular timing map until you pass the various thresholds to switch to launch maps, so even if your transition is perfect in your launch map, you might stay on your regular map for a while and be causing a big jump when it switches. Usually I don't get very much knock when I try out launch maps. See my launch ignition map below.
Old Dec 25, 2011 | 04:25 AM
  #185
Evo3573's Avatar
Just read this entire thread. Im currently on tephra v7. I have my launch maps enabled. I am building about 7 psi off the line. Car blows the tires off which is fine. My only concern is my wideband is reading all the way lean. Is normal?
Old Dec 25, 2011 | 04:40 AM
  #186
stunt2's Avatar
yep, mine too. seems it's normal
Old Dec 25, 2011 | 04:50 AM
  #187
Evo3573's Avatar
Is this because of the fuel cut? My Nlts goes all the way lean also.
Old Dec 25, 2011 | 08:10 AM
  #188
Raptord's Avatar
Yes its normal, our launch control uses fuel cut, not ignition cut.
Old Jan 28, 2012 | 08:09 PM
  #189
10isace's Avatar
Just tried launching for the first time using the launch maps and it was AWESOME!!! This can be addicting
I might have to give drag racing a go this spring/summer.
Old May 7, 2012 | 09:05 AM
  #190
Kakihara's Avatar
Hi all,
I was told NLTS uses the launch maps is that true ?
I currently believe it does since I have the same boost during nlts and launch (11-12psi)
my question would be : what should I do to get more boost in terms of timing and afrs ? (don't want it for launch, my tires are already having a hard time but for nlts)
I can't post the maps here they aren't mine sorry (they are weird anyway)
Old May 7, 2012 | 09:47 AM
  #191
Raptord's Avatar
Originally Posted by Kakihara
Hi all,
NLTS doesn't use launch maps. You can't change fueling during NLTS because the engine is in a fuel-cut state during NLTS. In theory I suppose you could keep timing pretty low in the 100-200 load, high rpm range (the area you hit while using NLTS).
Old May 7, 2012 | 12:39 PM
  #192
Kakihara's Avatar
No1 Raptord, thx for clearing that out
nothing else to say other than launch maps and NLTS are great and work perfectly
Old Jun 24, 2012 | 08:45 AM
  #193
audiofan's Avatar
Here is my current launch map
It worked great on stock turbo and stock injectors. Now I have bigger injectors (PTE 1200) and It is really hard to launch using the 2 step, I'm flooding the engine and it bogs.
Shouls I lean it out, add timming or both?
Thanks for your reply
Old Jun 24, 2012 | 09:14 AM
  #194
Raptord's Avatar
I would just start by leaning it out.
Old Aug 5, 2012 | 04:09 AM
  #195
jhoganusaf's Avatar
So this has probably been asked a few times, but I only see 3 psi with the 2 step. I'm using a td06 20g turbo. Stock ecu and used ecuflash without tephra mod to enable launch control. It's set to 5k rpm. What boost should I be seeing and how can I correct this?
