Cobb AP: ?s on product, features, and various maps incl Perrin maps go here [merge]
Old Jan 7, 2010 | 06:15 AM
  #541
ugakirk's Avatar
Can you run a stage 2 with the stock cat-back?
Old Jan 7, 2010 | 07:38 AM
  #542
ak47m203's Avatar
i run stage 2 hks 93 oct, stage 2 cause i have a tpipe.
Old Jan 7, 2010 | 09:58 AM
  #543
Methodical4u's Avatar
supposedly you need the full tbe to go to stage 2 and you'll also want to remove the pill as well. If you are set to go to Cobb that's cool, if you don't wind up doing so, i'd email Mellon Tuning. Of course you would need a wideband o2, i'm waiting to get a retune with him whenever I get some money.
Old Jan 11, 2010 | 07:08 PM
  #544
Golden's Avatar
Lightbulb 2008 vs 2010 Cobb AP
Premise:
a) 2008 and 2010 Mitsubishi Evolution X's have the same parts and are the same car made in a different year.
b) The only difference between the 2008 and 2010 tunes are that that 2010 has Lean Spool enabled.
Conjecture:
The same maps that work for the 2008 should work with the 2010.
So, why is it that they are taking so long to make all new maps for the 2010? Am I missing something that is different between the 2 years?
Is there anything other than the lean spool that is actually different between the 2 cars? No other aftermarket manufacture has made a distinction between the 2.
What this boils down to is, I have have my my AP and I am going to get a pro tune on it. But in the mean time, I would like to load an off the shelf Map into my car. I can't even connect it to my car right now, because there isn't even the stock map out.
Old Jan 11, 2010 | 09:23 PM
  #545
HB Speed's Avatar
Originally Posted by Golden
Premise:
Conjecture:
While some of the values are the "same" in the maps
Fuel , ign , etc the actual LOCATIONS of those maps are not the same
THAT is what is taking a bit
HB Speed does the CA beta testing for these car and i can assure you that it will all be released soon
Old Jan 11, 2010 | 09:50 PM
  #546
Golden's Avatar
That makes sense.
Are we able to tune the AP manually? Like if I was to take it to a good tuner?
I know you can, but you are too far from me.
Old Jan 11, 2010 | 09:58 PM
  #547
HB Speed's Avatar
That makes sense.
it will be just like the 08
so yea
Old Jan 11, 2010 | 10:05 PM
  #548
Golden's Avatar
Would I mess my car up if say, I loaded it with the stock 08 map that comes with the ap?
Old Jan 13, 2010 | 07:04 AM
  #549
Jor-El's Avatar
so, does this AP work with the jdm version evo x?
When I went to the cobb site, I only saw maps for the usdm evo
Old Jan 13, 2010 | 07:03 PM
  #550
darthvader's Avatar
Jdm ap
YES IT DOES ON THE 2008 BUT IT IS STOCK MAP YOU WILL NEED A TUNER TO ACHIEVE PERFORMANCE INCREASE
Old Jan 13, 2010 | 07:16 PM
  #551
darthvader's Avatar
Cobb accessport
YES 2008 ARE SUPPORTED YOU WILL NEED TUNER FOR PERFORMANCE MAPS
Old Jan 14, 2010 | 02:44 AM
  #552
HB Speed's Avatar
Originally Posted by kadabra
Hey
Sorry if this question appeared earlyer.
I was looking to get an Cobb AP and found no "tuned" maps for European models? Does this mean that Cobb will never support EU models? Or is it just a matter of time?
How big is the difference us ecu with eu ecu?
I can help you!
Old Jan 15, 2010 | 04:39 PM
  #553
Bear.914's Avatar
is there any chance of cobb releasing a map for the X that has Ams-intake,exhaust,intercooler+hard pipes
Old Jan 15, 2010 | 08:00 PM
  #554
Golden's Avatar
Yes, this one should do the trick:
Stage2+AMS 93 Octane
Stage2 with AMS intake system, using 93 Octane fuel. Requires turbo-back exhaust. +28% HP / +19% lb. ft. May require boost control system changes
The intercooler and hard pipes don't matter.
Old Jan 17, 2010 | 11:11 AM
  #555
Snail_Addict's Avatar
Anyone running the AP on their 2010 GSR?? Even though Cobb hasn't released a firmware update yet...
