Cobb AP: ?s on product, features, and various maps incl Perrin maps go here [merge]
.. feel free to correct me if Im wrong *COBB
UPDATE***
I just spoke with Chris @ COBB and asked him about the K&N drop in with the stage 1 tune @ stock air intake system and he explained that it is possible that the K&N panel filter could lean the car out perhaps to much, what he reccomended was logging the fuel trim (both short and long) while doing some city and hwy driving, but not full throttle or full boost, then add the short and long trim values together and record this value. Do this with the Stage 1 stock intake map, as well as the Stage 1 HKS PF (panel filter) map and which ever fuel trim value (Short + Long) is closer to 0 is the map you should use.
If you have specific questions or are unsure of how to do this, I would reccomend speaking with Chris or someone at COBB, I am not trying to missinform anyone but that is what I got out of our conversation.
Just installed the COBB AP stage 1 and am very happy with how much smoother the car is a both part and full throttle, there are no more dips or flat spots that came in the car's stock tune..
This is the 2nd AP I have owned (different vehicles of course) and I have been very happy with both, as well as COBB's support and customer service A+
Have you downloaded the latest version of AccessPORT Manager 2.0? Typically you cannot use the AccessPORT as a drag and drop device with windows explorer. Also, there is a limit to how many maps you can put on the AccessPORT so if you are unable to copy more on, take some off the device.
You can find the latest version of Manager here: http://www.cobbtuning.com/info/?id=3059
You will need a pro-tune for that, the OTS maps are all built around the stock solenoids. If you aren't nearby to a tuner and are willing to make the tweaks yourself it shouldn't be too difficult if you really want to get a 3-port.
I just uninstalled my AP to start using ECUflash. NOw i have a service engine soon. Is it because i am on a stock tune with a AMS intake and the MAF is off due to no tune?
Anyone know if there is an alternative map that would work with the HKS Racing Suction Reloaded intake? From what I've read, there are some maps that work with different intakes that isn't supported by cobb as of yet.
Right now I'm currently running a Stage 2 93 octane map with the following mods with no issues
AMS turbo back exhaust with HFC
Tomei UICP
I want to install a HKS Racing Suction Reloaded intake into my car. I know you need a pro tune to get it working correctly and cobb currently doesn't support it yet. Since the evo is my DD car, I just want a map that works until my pro tune appointment.
Any advice on what works?
Tomei UICP
Tomei UICP
Tomei UICP
