Cobb AP for 2011 Evo X?
Old Jun 19, 2011 | 02:29 PM
  #331
BakaUnchi's Avatar
Originally Posted by Gtidan
will you have a tune for a stage 1 with a works drop in filter?
just run the cosworth map once its out
Old Jun 19, 2011 | 02:30 PM
  #332
BakaUnchi's Avatar
Originally Posted by AkumaMotorsport
Baka-
I am curious what data you have on the Synapse DV? I use this valve regularly and on many builds and I find it to be one of the better valves on the market. The physical attributes are excellent and the valve reacts lightening fast. How can the DV cause a boost spike?
Any insight would be appreciated. Maybe there is a way to limit these issue for customers in the future. I am always willing to help as well.
John
Causes some spikes between shifts especially wit those who shift let boost drop then get back into it ie spooling the turbo @ like 5k
Old Jun 19, 2011 | 03:53 PM
  #333
jthompson8692's Avatar
Originally Posted by BakaUnchi
NO
we only have stage 1 gsr maps right now (stage 2 coming asap)
RA and MR have stage 2
Would a stage 2 map be safe for a stock 2011 MR?
Old Jun 19, 2011 | 04:20 PM
  #334
Kracka's Avatar
Stage 2 is designed for a turboback exhaust, run the Stage 1 since it's designed for an otherwise stock or stock + intake car.
Old Jun 19, 2011 | 04:46 PM
  #335
Gtidan's Avatar
anyone know when stage 1 will be released?
Old Jun 19, 2011 | 05:22 PM
  #336
sfearl1's Avatar
edited
Old Jun 19, 2011 | 06:19 PM
  #337
MikeD's Avatar
Well the cobb site is back up but still no 2011 maps! booo
Old Jun 19, 2011 | 06:42 PM
  #338
Kracka's Avatar
When are the 2012 maps coming out?
OBDII port is under the dash near your left knee.
Old Jun 19, 2011 | 06:46 PM
  #339
sfearl1's Avatar
Found it 2 seconds after I posted
Old Jun 19, 2011 | 06:47 PM
  #340
guswaym's Avatar
is mitsu even making a 2012 evo
Old Jun 19, 2011 | 09:40 PM
  #341
Golden's Avatar
I'm not even sure if 2011's are still coming out of the plant.
YEY for Cobb's site being up.
Old Jun 19, 2011 | 10:07 PM
  #342
BakaUnchi's Avatar
Use whatever map you want but if it blows up
We only have stage 1 2011 GSR right now
but it will work well on stage 2 Cars as well
Again the 2011 maps are designed by ME
not the same tunes as the 2008-2010
SEE ABOVE
Originally Posted by Golden
I'm not even sure if 2011's are still coming out of the plant..
Production till @ least 2012
Old Jun 19, 2011 | 10:58 PM
  #343
rmondoh's Avatar
the older V2 (not V2B) Do log a bit slower currently (thats why we moved to the new cables)
There are some more logging improvements coming down the pipe, ala GT-R style logging which is now up to 39 items @ 34HZ i believe !!
does that ?
Yup! Much appreciated. Keep up the good work!
Old Jun 20, 2011 | 06:50 AM
  #344
sfearl1's Avatar
this
Old Jun 20, 2011 | 11:17 AM
  #345
project_skyline's Avatar
Do v2 cables have the white plugs or how do you know which version you have?
