Cobb AP for 2011 Evo X?
Old Aug 14, 2011 | 08:34 AM
  #721
BeyondLimitsEvo's Avatar
^i'm in the same boat as you right now with the same mods, but just on a mr. i had an 03 gsr for 6 and a half years and i sold it for this and i love it. i did some logging with my ap and i think my fuel trims aren't right so i'll be putting the stock airbox back on today, but i'm going to keep the inlet tube and uicp on in hopes that everything will function properly. i did 2 3rd and 4th gear pulls and a few minutes of higway cruising around 65 mph and the ltft and stft are a little wacky. also under wot around 23 psi of boost i'm getting as much as 3 counts of knock
Old Aug 17, 2011 | 08:52 PM
  #722
Kaju's Avatar
I got my AccessPORT and loaded the beta firmware on it. It looked good to go. Tried to install it on my Evo and it could not communicate with the ECU. I called Cobb and they wanted me to send it back so they can take a look at it. The first mod for my Evo was an epic fail.
Old Aug 17, 2011 | 09:09 PM
  #723
fast08's Avatar
Where did u get your AP?
Old Aug 17, 2011 | 10:33 PM
  #724
Kaju's Avatar
Perrin Performance. I bought it from them so I can have access to their maps when they release them for the 2011 Evo.
Old Aug 18, 2011 | 05:18 AM
  #725
user 629782012's Avatar
my cobb hard pipe kit arrived. i'll be doing some more logging.. lol just wish i could figure out how to use atr. I'll post up some new loggs at some point in the weekend after their installed.
heheh can't wait!
jc
Old Aug 18, 2011 | 09:53 AM
  #726
AutoMotoSports's Avatar
For those guys that dont want to to wait we have e tunes available for the 2011 Evo X's. We have done a good amount of them already!
Contact us if anyone has questions.
Mitch M
Old Aug 19, 2011 | 08:05 AM
  #727
mrMTB's Avatar
You loaded BETA firmware on something and call it an "epic fail" when it doesn't work? Cobb will figure it out, but it's BETA for a reason...
Old Aug 20, 2011 | 06:39 AM
  #728
Kaju's Avatar
Originally Posted by BakaUnchi
nothing is beta anymore
the only reason its considered Beta is because we haven't added international support yet
I still understand what you are saying. I was just eluding to the first mod I do fails. In this case it just happens to be an ECU flash.
Old Aug 20, 2011 | 10:14 PM
  #729
arya24's Avatar
how do u guys like the stage 1 jump for gsr's?
Old Aug 20, 2011 | 10:19 PM
  #730
sfearl1's Avatar
^^ it's like night and day man, it really brings the X to life!
Old Aug 20, 2011 | 10:29 PM
  #731
arya24's Avatar
i really wanna get the ap but i feel like the performace upgrade wouldnt be worth the money. anyone got vids of them flashed or anything?
Old Aug 20, 2011 | 11:54 PM
  #732
souji's Avatar
Picked one up at the Cobb BBQ where they did the initial setup and quick run through. I agree. Its a lot more responsive with less lag. Should have been like this from the factory. Did notice on the 91 Stage 1 map there is a slight hesitation on WOT between 3rd and 4th. It jumps around 7.5k for a second or two before shifting.
Old Aug 21, 2011 | 12:37 AM
  #733
sfearl1's Avatar
i got mine used for about $100 less than they are going for brand new. i just saw one sell for $300 recently...
imo, they're well worth the money spent if that's all you're going to be doing to the car mod-wise.
Old Aug 23, 2011 | 01:43 AM
  #734
oozkarao's Avatar
Interesting; I have been using the beta Stage 1 on my '11 for about a week now as well and I didn't feel much of a difference. It feels stronger all around, and even though the turbo lag feels similar, it feels a bit stronger before the 3K now. The biggest change for me acually was that the stock EVO was running out of breath after ~5000 RPM, while stage 1 keeps pulling better until redline..
In short, it feels close to stock in my opinion, except at the high RPM range..
What boost numbers are you hitting on 3rd and 4th gears? On 4th and 5th, I'm hitting 27 PSI, and 26 PSI on 3rd.
Old Aug 23, 2011 | 06:44 AM
  #735
sfearl1's Avatar
^ i'm actually on a custom map from Jon now that started out as the alpha stage 1... i'm no longer stock though so it would be comparing apples to oranges if you're still stock (i'm running a cat-back exhaust, test pipe, uicp and panel drop-in). i can see if i still have my logs around from the stage 1 pulls i made on the alpha map... i'll let you know.
