Cobb AP for 2011 Evo X?
Old Aug 27, 2011 | 08:29 PM
  #751
sfearl1's Avatar
I think ACN = Arizona California Nevada
Old Aug 27, 2011 | 08:46 PM
  #752
Kracka's Avatar
You're probably starting your pulls too high, the boost maps are designed to taper off as the RPM's increase; you should be seeing peak boost in the 3500-4000 RPM area.
ACN = AZ/CA/NV 91-octane ****; yes, it's worse than normal 91.
Old Aug 27, 2011 | 08:48 PM
  #753
Kracka's Avatar
Here are the boost plots for both stock 2011 and Stage 1 OTS 2011:
Old Aug 28, 2011 | 09:46 AM
  #754
glamcem's Avatar
Unhappy COBB 2011 Stage 1 with CRAPPY GAS MILEAGE!!
Is it just me or there are some other having the same issue with the Cobb AP. I know when you make more power it results you worse gas mileage. However, when I had my STI it didn't change that much. Since the stock map is richer I thought Cobb Ap might have a positive effect.
Maybe it is because I only have 400 miles on the clock and have been running little aggressive and data logging might have caused that..
I averaged 12.3mpg with my last tank
What do you guys average with Stage 1 map?
Oh btw, I don't use gauges to calculate the MPG since it fluctuates and reset itself but rather fill up the tank and do the math.
Old Aug 28, 2011 | 09:50 AM
  #755
duhveed's Avatar
How about drive normal for a tank and report back
I average 16-20mpg
Old Aug 28, 2011 | 09:53 AM
  #756
punk3r's Avatar
i got an '08 MR with just Injen intake and Tanabe exhaust with COBB stage 1 and i'm averaging 22 MPG
Old Aug 28, 2011 | 09:57 AM
  #757
glamcem's Avatar
I average 16-20mpg
I am driving relatively off the boost(since my last fill up) and couldn't see above 16 yet( on the gauge) but yeah I will calculate and report back for sure..wanted to see what others are getting with a granny-style driving ..
I wonder if the 20+mpg is possible with some 70mph cruise..
thanks for the input, btw
Old Aug 28, 2011 | 10:00 AM
  #758
glamcem's Avatar
wow, that's awesome.. I wonder if the humidity and heat can affect the mileage that much( I live in FL) though..
I know that driving habits and a heavy foot can affect the mileage greatly and I didn't get this car for the fuel economy for sure but ..it would be nice to reach over 20+ mpg if I wanted to do so
Old Aug 28, 2011 | 10:03 AM
  #759
glamcem's Avatar
oh punk3r, almost forgot to ask how can you run a stage 1 map with an intake ? assuming your Tanabe is a CBE
Old Aug 28, 2011 | 11:03 AM
  #760
punk3r's Avatar
I got the Injen intake kit with the UICP and yup the Tanabe is a CBE. I'm running the Injen COBB stage 1 because I asked COBB and they say to run the stage 1 with the CBE.
Old Aug 28, 2011 | 12:34 PM
  #761
BakaUnchi's Avatar
The Mapping is only LEANER in boost.
Cruise/light throttle = EXACTLY THE SAME AS STOCK AFR 14.7
If you want to MAXIMIZE mileage watch Load on your AP and stay UNDER 90
I get 23-25 @80mph and my "econo" map gets 29mpg IN town if you drive like a grandma
Your Mapping is made by ME soooooo, i blame the user's right foot.
K THX BAI
Old Aug 28, 2011 | 12:53 PM
  #762
Kracka's Avatar
If you care about gas mileage get a lighter right foot, simple as that. Even though it's tuned leaner in boost, boost has been raised so you're actually burning more gas to compensate for the additional airflow.
Old Aug 28, 2011 | 01:01 PM
  #763
glamcem's Avatar
very interesting because as I read the map notes(for stage 1 93 octane map) I see that they clearly stated:
Description: Stage1 93 v107 - Intended for an otherwise stock
2008/2010 Mitsubishi EVO X GSR & MR/MRT and the 2009 Mitsubishi EVO
X World Market vehicle with a stock or cat-back exhaust, STOCK
INTAKE SYSTEM, and STOCK INTAKE FILTER ONLY
. 93 or 94 octane fuel.
Boost Targets: ~24psi peak boost pressure tapering down to ~17psi
by the 7500 RPM redline, +/- 0.8psi.
Hardware Requirements: Otherwise stock vehicle with a STOCK INTAKE
SYSTEM and STOCK INTAKE FILTER ONLY
. The addition of any other
hardware may make the vehicle perform poorly.
Old Aug 28, 2011 | 01:04 PM
  #764
Kracka's Avatar
Note what I underlined. Punk3r also stated he is running the Stage 1 OTS map designed for the Injen intake (he does not have a 2011).
Old Aug 28, 2011 | 01:07 PM
  #765
glamcem's Avatar
K THX BAI
oh HAI thanks for the reply ,
don't get me wrong mileage is not really my main concern since I pursuit the performance as you may guess.
I just want to see what kind of gas mileage is attainable with a careful driving,
You said you are getting 23-25 @ 80mph , that's just amazing with a car putting 560whp
. or is it before the mods ?
thanks in advance
