Cobb AP for 2011 Evo X?
Old Aug 31, 2011 | 09:34 PM
  #796
BakaUnchi's Avatar
Originally Posted by BakaUnchi
MR OWNERS WITH LOW BOOST TRY THIS MAP
http://www.mediafire.com/?fmjvh93qfa0qx44
Originally Posted by mbspeed
i just got a cobb tuner for 2011 mr and i was told stage 1 map would work???
please use this
Old Sep 1, 2011 | 07:03 AM
  #797
RAPTR's Avatar
please use this
Finally hit 24psi!
Old Sep 1, 2011 | 09:50 AM
  #798
guswaym's Avatar
Originally Posted by RAPTR
Finally hit 24psi!
cobb ots maps are alright but a pro tune is were you want to go 28psi ftw
Old Sep 1, 2011 | 12:09 PM
  #799
BakaUnchi's Avatar
the last map i posted has the boost "turned up to 11"
no matter what anyone does (unless u add a pill) it wont go above what its hitting on that map
Old Sep 1, 2011 | 12:38 PM
  #800
RAPTR's Avatar
On the ACN 91 v301 I couldn't get above 20-21psi so I'm happy with 24psi and I got only 1 count of knock that happens randomly so I would say the v302 is a pretty safe map.
Did you do any revisions on that map for the SST shifting? This might just be placebo but it seems to slip the clutches less in Normal mode.
Old Sep 1, 2011 | 01:59 PM
  #801
BakaUnchi's Avatar
On the ACN 91 v301 I couldn't get above 20-21psi so I'm happy with 24psi and I got 1 count of knock that happens randomly so I would say the v302 is a pretty safe map.
Old Sep 1, 2011 | 08:14 PM
  #802
arya24's Avatar
cobb dyno on the ap said i was at 362 to the wheels on a completely stock car running stage 1.
Old Sep 1, 2011 | 08:25 PM
  #803
mbspeed's Avatar
Originally Posted by oozkarao
There is Stage 1 available for '11. Hook up your AccessPort (before installing to the car) to your PC, make sure you check "Check for beta software updates" in Options, go to firmware update section, and upgrade to the beta software. After that, once you connect your AP to your car, it will recognize your car properly.
I did the car fall on it face with the cobb tune installed only hit about 22psi on boost
Old Sep 1, 2011 | 08:38 PM
  #804
BakaUnchi's Avatar
you used this map?
Old Sep 1, 2011 | 08:45 PM
  #805
oozkarao's Avatar
I don't get it. What does that mean? Car fall on it face?
Old Sep 1, 2011 | 08:50 PM
  #806
BakaUnchi's Avatar
my guess is a boost cut.
Old Sep 2, 2011 | 03:28 AM
  #807
Grimshaw's Avatar
Jon any chance to see a 93oct of that new map for the mr?
Old Sep 2, 2011 | 01:24 PM
  #808
tnn35's Avatar
Hi Jon
I took your advise and install map 302 back on my MR. This time, instead of going out right away and try to beat it up to get the boost number or feel the power, I just normally drive it.
I pay attention and notice a little power gain from 5k rpm -> redline compare to stock, definitely I can feel it on 1st, 2nd gear.
I log using AP, boost show -12/25 on LED so I guess my max boos is 25psi at some moment.
MPG is not that bad. my normal DD with my driving style on stock map : 19mpg. With 302 map, I get 16.5mpg
Overall: I'm keeping the map. ;-)
Old Sep 3, 2011 | 04:41 AM
  #809
Jubey97's Avatar
Unhappy low boost beta map 2011 gsr peak 21 psi?
just got the accesport for the 2011 gsr. the beta map just gets me to 21 peak boost. is that normal? is there anyway to increase boost?
Old Sep 3, 2011 | 04:51 AM
  #810
Jubey97's Avatar
just got the accesport with latest firmware today for the 2011 gsr. using the 93 octane betamap. the beta map just gets me to 21 peak boost and tapers down abit low i think. is that normal? is there anyway to increase boost? engine knock count sometimes hits 19! car is completely stock with 2k miles. logs where done in grand prairie texas. hope i dont have a boost leak somewhere, but the car is almost brand new and never been tinkered with. its my DD. need some help. https://docs.google.com/spreadsheet/...hl=en_US#gid=0
