launching?
Old Apr 20, 2006 | 08:27 PM
  #31
matute's Avatar
Good for u Keep with what works for u i will do the same.
If u read carefully the first thing i wrote is that the 60 times i posted were in a 165 hp impreza and that i knew it was not the same i also sayd thet i had done that in some wrx's that i have driven and it worked great in both et and mph
PS. The guy asked for advise, i gave mine if he likes it great if he doesnt good, but i dont think i sould be condemend just because i dont do things like everybody else or just becuse u dont like what i do. it hink u were just a little bit rude and that is not the porpuse of this forum. This forum is so that every owner can give his point of view so that the ones that have doubts can make an educated decision. Not to burn people when their ideas dont go with yours. Have a good evening.
Old Apr 20, 2006 | 08:40 PM
  #32
Warrtalon's Avatar
You didn't say you did 1.5s in WRXs in that first post, though, yet you made sure to point out the crappy 1.9-2.0s, so I think you're just making stuff up now to cover that terrible launch method you suggested.
I highly highly recommend against ANYONE DOING THAT METHOD in any car, no matter if it's 165hp or 500hp.
Old Apr 20, 2006 | 09:00 PM
  #33
raiceboi697's Avatar
that method of launching is so crazy my clutch is starting to go just thinking about it
Old Apr 21, 2006 | 04:30 PM
  #34
Unlimited's Avatar
By modulating, I ment the amount of throttle you give.
For example, with a 2 step set at 6,000, it will bounce at 6,000 til you engage the gear
But while your bouncing it, are you giving it full throttle or like half throttle?
What I'm practing ATM is letting it bounce while giving it partial throttle, then slipping it out quickly while gasing it.
Old Apr 21, 2006 | 04:59 PM
  #35
dsmfan95's Avatar
I full throttle mine off the 2step limiter. Then I slip it out while holding the gas to the floor.
Old Apr 21, 2006 | 05:08 PM
  #36
Unlimited's Avatar
I'm assuming you have the restrictor pill removed? Do you have an upgraded clutch?
Old Apr 21, 2006 | 05:09 PM
  #37
dsmfan95's Avatar
Nope and stock clutch.
Old Apr 21, 2006 | 05:17 PM
  #38
Unlimited's Avatar
Your tech must work with your 1.66 60'
But whenever I try this, my clutch "unloads" and won't grab.
Then It will grab once I shift into second and I smell clutch everywhere.
Any suggestions? I thought that with a restrictor pill it was almost impossible to
launch the car hard.
Old Apr 21, 2006 | 05:36 PM
  #39
559EVO's Avatar
I have dropped the clutch about 50 times already with no drivetrain problems, I do use matutes technique also. If your tires are inflated past 40 psi it will spin more and not shock your drivetrain, I do agree that I'm taking a chance on breaking but it works if done right.If your dropping the clutch and you EVO is bogging then put air in the tires or rev higher then drop it.Slipping the clutch is the safest way for your drivetrain but it will eventually kill your clutch.In pro drag compitition there is no time for a clutch slip on 600+ hp cars. If its your daily driver and you dont have extra $$ just in case dont drop the clutch.
Old Apr 21, 2006 | 05:40 PM
  #40
dsmfan95's Avatar
I can't really tell you lol, I just go based on the feel of the clutch. I bounce it off the limiter, then quickly slip out the clutch all at once.
dfarmer0033
May 18, 2017 08:43 AM
bboy_RES
Mar 30, 2008 08:40 PM
Derek888
Nov 5, 2004 07:45 PM
EvolvedfromaWRX
19
Aug 6, 2004 09:10 AM
rblader86
Dec 3, 2003 05:17 AM
