evodan2004's attempt at 9s take 1... failed
Old Jun 30, 2011 | 12:45 PM
  #211
06MREvo's Avatar
Originally Posted by 4g63evoeight
a stiffer hallmann spring? i think i have the standard one in mine, hits 32psi but it tapers quite a bit.. maybe the stiffer spring would help
Originally Posted by evodan2004
i have no clue. i will find out. i hope it is indeed stiffer then the normal stiff spring.
haha, trust me, the spring is definitely stiffer. I could feel it by just compressing the springs with my fingers. It wasn't as big of a difference like with their soft spring & the old stiff spring but you can still feel it. I had my MBC set to 26-27psi with their old stiff spring, I put the new stiff spring in and turned the boost down close to 3 full turns and figured that would be enough, wrong. I let off when I saw 33-34psi haha. I had to crank the knob almost all the way out to get back down to my 27psi. I am using the ceramic ball with the new stiff spring and it seems to taper maybe 2psi.
Old Jun 30, 2011 | 01:13 PM
  #212
4g63evoeight's Avatar
gotcha, didn't you mention in another thread that if you have the hallmann they would send you the spring no charge?
Old Jun 30, 2011 | 02:24 PM
  #213
EvoDan2004's Avatar
they sent me a spring no change. now i am just waiting for it
Old Jun 30, 2011 | 02:40 PM
  #214
what did you do? call/email hallmann direct?
Old Jun 30, 2011 | 02:43 PM
  #215
EvoDan2004's Avatar
i called and i said yo. i am a bad motha f%^ka. they said o snap ok you need a stiff spring. its free. ill send it right away.
haha.
i called them up. explained my issue and they said they have a super stiff spring that most turbo diesel guys use for 40+psi. i said i will buy one. she said no worries just give me you address. and that was it.
Old Jun 30, 2011 | 02:48 PM
  #216
06MREvo's Avatar
This is exactly how it happened for me too...
Old Jun 30, 2011 | 03:03 PM
  #217
LGshow19's Avatar
haha.
Email worked fine for me
Old Jul 1, 2011 | 01:14 PM
  #218
BigT's Avatar
Island is closed tonight. I'm going tomorrow at 2pm. Its open for test n tune and gamblers races only.
this friday. and then sunday.
Old Jul 1, 2011 | 03:00 PM
  #219
EvoDan2004's Avatar
Nice man. I got my spring today but did not get the nlts setup yet so I probably wont be going.
Old Jul 1, 2011 | 04:12 PM
  #220
Sean@Iveytune's Avatar
Closed? Man i was about to head over there :-)
Sean
Old Jul 1, 2011 | 07:51 PM
  #221
EvoDan2004's Avatar
here is the normal still spring VS the super stiff spring. normal on the left. super stiff on the right.
Old Jul 1, 2011 | 10:45 PM
  #222
BigT's Avatar
Sweet. Did you get it installed yet?
Old Jul 2, 2011 | 06:10 AM
  #223
EvoDan2004's Avatar
Yea its in. I might try it out today.
Old Jul 2, 2011 | 05:57 PM
  #224
BigT's Avatar
Good thing you didnt come today. It was super HOTT on the track. My car was hitting 240 degrees by the traps.
Old Jul 2, 2011 | 06:03 PM
  #225
EvoDan2004's Avatar
i normally see 210 at the traps. 240. she is getting HOT. how did you do?
