evodan2004's attempt at 9s take 1... failed
Old Jun 20, 2011 | 02:42 PM
  #91
06MREvo's Avatar
Originally Posted by evodan2004
HAHAHA. well all i did was clean off the sensor and i cleaned out that hole. 25psi. car pulls clean to 8k. 30psi. clean. i said F this. go for the gold. 44psi. ''oops'' turned it up to much. backed it down. 40psi. clean 8k HIT 4TH. clean 8500rpm.
soooooooooooo im kinda confused. is it fixed? do i put the spark tech on or leave it alone.
only issue now is i do not spin the tires in 2nd gear nike my nittos did. these hoosier tires GRIP. so that only means i need more power.
hahah...yes!!
Old Jun 20, 2011 | 02:46 PM
  #92
LGshow19's Avatar
Always something so simple.... good stuff man
Old Jun 20, 2011 | 04:33 PM
  #93
EvoDan2004's Avatar
i placed an order for 2 cam sensors. is it the issue? i dont know. but i cleaned it off and the car works perfect so im running with it. if it is not the issue then ill put the sensors in the OEM box i have. haha. but i think it is solved. tonight the c.o.p. go's back on and tomorrow retest.
Old Jun 20, 2011 | 07:51 PM
  #94
evodude32's Avatar
Dan, it could also be the CAS harness itself, I know atleast with my car and a couple of other evos that I have worked on if you wiggle the wires going into the CAS it makes the problem go away. My car if I'm cruising on the freeway in hot weather for long period of time, the CAS will start to drop signal making the car jerk and cut out every now and then.
When it does this I have to pull over and wiggle the wires around then it goes away..
I have taken the harness apart 3 times and have yet to fix the problem, but I find it odd how I can wiggle the wires leading into the CAS and make the problem go away..
Old Jun 20, 2011 | 07:54 PM
  #95
EvoDan2004's Avatar
the the sensor harness part of the engine harness or is it able to be removed?
Old Jun 20, 2011 | 07:58 PM
  #96
evodude32's Avatar
The harness that plugs right into the CAS. The wires coming out of that plug, I wiggle mine and the problem goes away.
Old Jun 20, 2011 | 08:00 PM
  #97
EvoDan2004's Avatar
i know that. but when you unplug it from the sensor how can i remove the harness ''just the few wires for that sensor'' is there another plug else where or is it linked into the stock engine bay harness.
Old Jun 20, 2011 | 08:05 PM
  #98
LGshow19's Avatar
So that means track this friday?
Old Jun 20, 2011 | 08:08 PM
  #99
EvoDan2004's Avatar
i am working nights this week. so it means track ASAP. if work cancels wed or fri then its go time. otherwise it is sunday.
Old Jun 20, 2011 | 08:11 PM
  #100
evodude32's Avatar
Oh i see what your asking. I just de pinned the wires with the harness still in the car (battery disconnected of course) Then I had some extra pins laying around and re pinned the harness. It didn't fix the problem so I have no clue what causes it, all I know is wiggling those wires clears the problem up for me.
Old Jun 20, 2011 | 08:12 PM
  #101
LGshow19's Avatar
Get video again. Wanna see you get that 9sec pass
Old Jun 20, 2011 | 08:13 PM
  #102
EvoDan2004's Avatar
well when i get a new sensor on there and if i experience the same thing. i will give it a wiggle and see what happens. i hope others can learn from are experiences.
Old Jun 21, 2011 | 09:38 AM
  #103
EvoDan2004's Avatar
i put the c.o.p. on. took it out. broke up. so now i just put the stock back on again and i am going to go test it. this is driving me up the freaking wall. waiting for a cam sensor to show up. it may not be the problem. but i want it replaced anyways now.
Old Jun 21, 2011 | 10:03 AM
  #104
EvoDan2004's Avatar
stock ignition. clean. no problems.
i just dont understand. its running clean right now. the car is not moving until i can get to the track.
Old Jun 21, 2011 | 10:12 AM
  #105
PATRICK B.'s Avatar
Dan glad you are at least on the right track to figuring the issue out!
Sorry if you mentioned it in a prior post but what COP are you running?
I recently saw first hand a SpoolinUp COP (non-cdi) that had some wiring issues on a customer's Evo when we tried to fire it up after the motor puked a rod and was replaced.
Ran like it was on 3 cylinders and since i had my SparkTech COP nearby i offered to throw it on to see if it helped and BAM no issues at all!
I try not to bad-mouth any company out there regardless of if they are a vendor here or not but i'm not too impressed with the quality of those kits
