UTAH - custom tunes - March 5, 05 - sign ups
Just pay pal $86.99 to paypal@dynoflash.com and I will ship on out monday via priority mail - it comes with an install kit and directions
Hey Al, if I was to get tuned for 91 octane, what would happen if I ran on 100 octane at a race? Higher octane is safer for the car, so I'd like to be able to switch at the track without the tune causing problems... would it work just like putting 100 octane in the car now, add a little bit of hp but not as much as it could with a full tune on 100 octane?
But it'd still be safer and not cause any problems with a 91 octane tune? Like, I wouldn't lose power, or be running weird/rough?
AL i have a few questions for you, the reason i'm doing your flash is with my current setup & 780cc injectors i'm getting 25 degrees of total advance which is not acceptable on pump gas!!!!the afc is doing this because i have to pull out -20 to -30 on fuel so my ecu is thinking it can run a **** load of timing.) what kind of timing have you been doing on pump gas (91)(13 to 18?) you can get mine down tons correct??? i'm looking forward to making good power with your flash.
thanks, zach[/QUOTE]
al any info?????
al any info?????
thanks, zach
thanks, zach
I can set the timing whereever you want
Yeah, there is a point, it's A LOT safer on the engine then crappy 91 and all the other parts the fuel runs through... I don't want ANOTHER blown engine... That, and it's the easiest fuel to get on location at a track. Al seems to suggest it'll run just fine, maybe a bit rich but shouldn't lose any power compared to 91 octane, and allow me to crank up the boost to ~23 from 20... and that'll add that bit of power, but other than that I won't gain anything from the higher octane.
