Best pump to use for E85
Are there any surge tanks that use the Walbro 450? There are a bunch that use 044 type of pumps but I'd like to keep it simpler. I'm going to be using the setup in a 280z. Ideally I'd like to just feed the surge tank with a new external pump so I can keep the stock tank in place. And yes, the stock tank has already been taken apart and treated to use E85.
The fuel tank on my Z was full of sludge from sitting for years, and the tank had begun rusting on the inside. I had to split the tank in half, sand blast it then re-treat the metal which was basically just a type of epoxy applied to the inside and outside.
Ah, so it wasn't corrosion due to E85.
FS[Northeast]: Aeromotive 340lph E85 Pump | Torque Solutions Pump Holder | OEM Fuel Pump/Sender Assm
CrazyLilPunk
Apr 24, 2016 04:17 PM
DaleRae
Jul 6, 2010 04:37 AM
tony gibson
25
May 4, 2009 06:56 AM
