ECUflash tutorial for beginners
Old Jun 3, 2006 | 06:39 PM
  #136
mchuang's Avatar
Originally Posted by elhalisf
well, then what is "good" timming?
In respects to both fuel and timing start conservative with both. For fuel you need to start rich and for timing you need to start low. I know you have proscan so if that things dyno feature actually works properly then when you add timing and make a 4th gear pull, you should see an increase in torque. Once you get to a point where you add timing and you see no torque gain just back off a few degrees. It is ok to sacrifice a couple of degrees and lose a lil hp for a safe tune unless you like to be on the edge
Old Jun 3, 2006 | 06:46 PM
  #137
elhalisf's Avatar
proscan has a dyno feature! SWEET!
i know the numbers wont be acurate, but atleast i can use it for before and after comparisons.
Old Jun 4, 2006 | 08:56 AM
  #138
mitsugsx's Avatar
I tried to search for this, but couldnt find a difinitive answer.
Is the flash data lost on the ecu if the battery is taken out or unplugged? I know this is true for the 2g DSMlink.
THanks
Old Jun 4, 2006 | 09:04 AM
  #139
Girlie's Avatar
THanks
No, you are rewriting the rom. The ram is what gets erased with power loss. Think of it as a base map vs realtime map if you are familiar with the AccessPort.
Girlie
Old Jun 4, 2006 | 10:39 AM
  #140
andenbre's Avatar
MalibuJack, EFIxMR, mchuang, Thanks thats some very helpfull info. now to figure out the mivec
Old Jun 6, 2006 | 04:21 AM
  #141
colonelfox's Avatar
This is a relative newbie question. I'm used to tuning using a logger and an Safc or MAFT. I have a dyno day at the end of the month but I'd like to yank the afc out and get rid of it in the meantime. I can sell it and buy new parts and my wife can't complain. Do the same tuning principals still apply as with a piggy backs using O2's, fuel trims, timing and EGT's, or does it become harder since you're working directly with the trims internally? I'm only looking for a baseline tune to get me from point A to point B for a few weeks without fouling plugs.
I just got the cable last night, raised the redline a hair and set it up for my 780's but I haven't uploaded anything yet.
Old Jun 13, 2006 | 07:08 AM
  #142
justchil's Avatar
Where did the pics go from teh first post
Old Jun 13, 2006 | 07:59 AM
  #143
cfdfireman1's Avatar
Verboten
Verboten
Old Jun 13, 2006 | 11:44 AM
  #144
mike1023's Avatar
ya werid did they go hey if you make it a PDF i can throw it on my web server if need to.
Old Jun 13, 2006 | 06:53 PM
  #145
05WhiteEVO8's Avatar
Does anyone know where a write-up is explaining all the values in each of the catogories? For example on the Boost limit what does 225 correlate to and what does 255 correlate to. Thanks
Old Jun 13, 2006 | 06:57 PM
  #146
EFIxMR's Avatar
Back up server hiccup!
Old Jun 14, 2006 | 10:35 AM
  #147
justchil's Avatar
Has anyone seen weird stuff when using increment/increase on a group of cells? For some reason some cells are fine and +.1 but some cells are not affected at all... one cell actually went up .2 points.
Thanks for fixing the images
Old Jun 14, 2006 | 10:43 AM
  #148
MalibuJack's Avatar
Its probably a rounding error.. Most of the cells are mathematically calculated values so going .1 at a time may result in rounding up or down, which can explain your results..
Old Jun 14, 2006 | 10:49 AM
  #149
b0ostedEV08's Avatar
225 mean 225 engine load percent at that given RPM range at 1000 ms will hit fuel/boost cut.
Old Jun 14, 2006 | 11:15 AM
  #150
Sure nuf.
Copy a cell and paste it to word or something like that. You will see that it carries the cell 3 or 4 points to the right of the decimal point. What you see is just rounding, changing a cell by .1 really changes it .1274 or there about.
