ECUflash tutorial for beginners
Old Jul 5, 2006 | 10:30 AM
  #166
Z_Lancer_Man's Avatar
I had a similar problem. All you have to do is go under "Options" and then select "Port" and make sure that the 1.3 Cable is selected. To do that, you must have the cable plugged in. Hope that helps.
Old Jul 5, 2006 | 10:52 AM
  #167
C6C6CH3vo's Avatar
Yeah, I found that out the hard way - 4-5 hours of headache - the driver is the wire - DUH! It's the obvious stuff I end up overlooking.
Well, I'm happy, allthough it took me 2 days to lowere my rev limiter from 7800 to 7600 lol
Old Jul 6, 2006 | 04:02 PM
  #168
justchil's Avatar
Good one
Old Aug 7, 2006 | 12:00 PM
  #169
Tuned by LIM's Avatar
Bump !!! very nice write up.
Old Aug 8, 2006 | 08:35 AM
  #170
erggy's Avatar
Hello P' Limp
Have you tried flashing any evos in thailand yet krub?
Old Aug 8, 2006 | 12:11 PM
  #171
Hi Erggy !
I got cable few days ago and tried flash Evo9 by EcuFlash program.
the cable work fine I can read and write ROM but couldn't view any map
just seen only Rev Limit and Speed Limit cause no the definition xml file for my ROM image version ( JDM 89280002 )
I also post like this in openECU forums for help then attached my ROM image
http://forums.openecu.org/viewtopic.php?t=827
everyone can go to download if interest...........
Old Aug 8, 2006 | 12:44 PM
  #172
nvr2fast's Avatar
Is this going to be stickied? I think it should!
Old Aug 9, 2006 | 05:35 AM
  #173
honda-guy's Avatar
where can i find the bin file for a stock 03 evo?
also, i have a custom flash from turbo trix. i'm not sure what software they use to do the flash. would i be able to read the turbo trix bin file with ecuflash?
thanks,
Old Aug 9, 2006 | 06:58 AM
  #174
Mad_SB's Avatar
thanks,
openecu.org, gotta create an account and login to see the attachements.
Depends on what they used, if it was ecutek, not at the moment.
Old Aug 9, 2006 | 07:30 AM
  #175
forbidden color's Avatar
By the way, if nobody mentioned this before, we got 2 stock evo 9 map out and there is a VVT controller for the Mivec with the new software, which was very cool to see.
Evo 8 stock map and evo 9 stock map is infinitely different, even the setups, which was cool too.
Old Aug 13, 2006 | 08:27 AM
  #176
joedr's Avatar
EvoM Moderator
Very nice work EFIxMR!
Congrats!
Old Sep 5, 2006 | 11:26 AM
  #177
EVOtagger's Avatar
could someone be so kind as to rehost the images
Old Sep 5, 2006 | 11:59 AM
  #178
EFIxMR's Avatar
links repaired. we have been moving servers and revamping our website, hence the disappeared images.
Old Sep 7, 2006 | 07:47 PM
  #179
Ralph's Avatar
I can't download the ROM.. in the first post =( Doesn't exist.
Old Sep 12, 2006 | 07:36 AM
  #180
WickedWhtMR's Avatar
So how do you enable launch ccontrol/2 step
