ECUflash tutorial for beginners
Old Jun 14, 2006 | 11:20 AM
  #151
justchil's Avatar
Gotcha! So I should probably edit these #'s in excel for better control?
Old Jun 14, 2006 | 11:30 AM
  #152
cfdfireman1's Avatar
Don't think so.
I beleive that's just how hex works but I'm no expert. Even if you try to set data with "=" 15.0 becomes 15.0528 and shows as 15.1 in the cell. 14.9 is 14.9333.
Old Jun 14, 2006 | 11:52 AM
  #153
MalibuJack's Avatar
Its just the value is some calculation from a hex value.. so a fraction value calculated and converted back to hex may get rounded when converted back..
Old Jun 14, 2006 | 11:55 AM
  #154
yep
Yea that. ^^^
Old Jul 3, 2006 | 11:08 PM
  #155
C6C6CH3vo's Avatar
Originally Posted by EFIxMR
I
As soon as I figure out a good way of presenting the material I will post a more advanced tutorial.
anything yet?
After I download that http://www.speedelement.com/images/...O8%20JM9693.hex
what do I do next?
Also I got an evo8 all I could find was the 1.28. Will that work or does it have to be 1.27
Old Jul 3, 2006 | 11:16 PM
  #156
EFIxMR's Avatar
Download the new 1.28 version. if you have your cable already all you need to do is hook up the cable, start the software, hit the download button and follow the on screen prompts.
Old Jul 3, 2006 | 11:18 PM
  #157
housedj's Avatar
ECUFlash for dummies! this write-up is amazing. good work man...
Old Jul 4, 2006 | 08:13 AM
  #158
C6C6CH3vo's Avatar
I managed to get evereything to scan the ECU but for all my maps the RPM and load values are waaaaaaaay messed up.
In the RPM column its like:
191
191
191
169304
389720
347820
2000
3000
4000
And in the load it goes up to 400!
It cant be real values the car runs fine, must be backwards axis
Old Jul 4, 2006 | 08:20 AM
  #159
MalibuJack's Avatar
Are you talking about reading the ECU rom with the cable? Your problem isn't the rom, its the definition, your Rom's definition is likely different than the one it got matched to (inherited?)
Its not too difficult to find the new ones, but you need to take down the ECU Identifier and see if it matches anything..
If your car had been reflashed with Techtom in the past, it might have a identifier that may not be in one of the definitions and Jason from Mynes (providing he has the time to still support this) can create a definition for a newly found ROM.. I can do it too, but I'm nowhere as proficient at it as these other guys, nor could I guarantee I could come up with something fast enough to make you happy. I'm in the process of working on one for another mitsubishi we did an experiment on.
Old Jul 4, 2006 | 08:54 AM
  #160
C6C6CH3vo's Avatar
Yes, I hooked my cable up with no intention to adjust anything but to see out of curiosity what my timing map was currently set to
Not clear about "definition" but I am original owner of car, cable, and ECU. Car was customed tuned by vendor with the most experience so it cant be that. I also matched the 04 96XXXXX8 # with the one on the ecu tag, if thats what is meant as "identifier"
Its not too difficult to find the new ones, but you need to take down the ECU Identifier and see if it matches anything..thats the 9620008 like # right?
ThANKS
Old Jul 4, 2006 | 09:08 AM
  #161
MalibuJack's Avatar
Originally Posted by C6C6CH3vo
ThANKS
Yep it looks like you got everything covered.. Its just odd that if you matched the ECU definition correctly, that the axis would be screwed up..
However, did ECUFlash ask you which one it is? Or did it find it automatically? if it had asked you, then it might not recognize the rom image (since it was reflashed, and likely with techtom some of the rom images used might have different identifiers not seen on any or few if any USDM model cars, which is why it might not have matched)
The best person to ask is the tuner you got your reflash from, if he does through the e-mail flashing, its possible he has your reflashed map on file and can convert it for you to use..
But I would refrain from adjusting anything, if the axes are wrong, then there are one or two other tables that could be wrong too, and it would really suck to have a no-run condition because of it..
FWIW the identifier on the external label isn't always the ECU/Rom identifier, especially if the car was brought in for any service or recall work during its warranty period. Even my car had an original 03 USDM flash, but its external labeling was something I couldn't match to anything in the USDM market..
Old Jul 4, 2006 | 09:16 AM
  #162
C6C6CH3vo's Avatar
However, did ECUFlash ask you which one it is? Yes, EFlash asked and had 3 options for 04 evo VIII
The best person to ask is the tuner you got your reflash from, It was a cutom tune last Oct, so nothing odd there, I must have screwed something up loading the setup
But I would refrain from adjusting anything, absolutely!, "DO NOT SAVE" pressed, my main objective now was to lower the RPM limits but now, until I figure out whats going on, I aint saving anything
FWIW the identifier on the external label isn't always the ECU/Rom identifier, especially if the car was brought in for any service or recall work during its warranty period Car had 18 miles on it when I purchased it, the ECU has been mailed to flash 2 times and custom flashed once, and never been touched by a mitsu technician.
I can't paste the actual map - (I'm using a vendor's product) but I will give the RPM scale just in case someone knows offhand what I'm doing wrong. One more thing, this is from the "READ FROM ECU" option:
191*
191
191
191
191
191
255996
255996
137383
39
500
1000
1500
2000
2500
3000
3500
4000*
My load values go up to 400,
*(Edited)
The above RPM and load tables are what may happen if you load the wrong ECU identifier for the year (04 has 3 or 4 different ECU ID's*
The actual map appears normal (at least to me) and I furthermore know that the ECU was scanned correctly because rev limit was 7805, the high and low octane maps were almost identical, the figures at the left of ign and afr charts were identical to stock, and so on.
Is it possible that the ECU doesnt read the actual given RPM value, say, 191 in my case, but reads it as corresponding rows? The car runs normal in fact, really halls bookie for the slowest known EVO 8 produced (04 SSL)
Hope I didn't clutter this thread toooo much,
Thanks
Old Jul 5, 2006 | 07:40 AM
  #163
05graphiteMR's Avatar
nice description
Old Jul 5, 2006 | 09:29 AM
  #164
MalibuJack's Avatar
Okay, so it sounds like there is no pre-existing definition for your ECU type.. At least on your computer or version of ECUFlash..
Typically when you open a map it recognizes, it just opens, it doesnt ask if you want to inherit or copy anything.. If it asked you anything like that, it means it didn't match anything..
Its pretty common to have some of the load/rpm etc.. axis definitions move around from rom versions and that is why you may see most of the table info correct, but the axis values look wrong.. Their not actually wrong, but the definition is looking for them in the wrong place.
I probably could help if I saw the map, but its likely the tuner you are dealing with has seen this already, and created a matching XML definition for it, and he can probably send it to you.
Old Jul 5, 2006 | 10:22 AM
  #165
C6C6CH3vo's Avatar
For everyone whos curious's information, the ECU identifier I used was wrong so the RPM/load tables were messed up. Working now!
- thanks.
Wheres my concerta
