ECUflash tutorial for beginners
Old Jun 21, 2007 | 07:02 PM
  #256
TouringBubble's Avatar
No problem. I enjoy helping others. Again, good luck!
Old Jun 22, 2007 | 10:02 AM
  #257
Jeff_Jeske's Avatar
Originally Posted by burgers22
Did you ever stop to ask yourself why they do this? I mean why remove something that will help prevent you engine going bang?
MB
You motor isn't going to go bang any faster than it will with you tinkering on other parts of the tune. I know many people running max boost the stocker can make which varies from day to day depending on the weather. When doing the standing mile we need much longer than a second.
Like I said get an EBC and have the safety and control.
Old Jun 22, 2007 | 05:21 PM
  #258
burgers22's Avatar
The stock turbo will not make 319 load, thats is about 31 psi. I think you miss understand my question. So let me put it another way. Why remove the safety of the boost cut all together? What is the point? By the time you get to 319 load (if you ever do) the knock will be off the scale and the boost cut can only be an additional safety measure.
MB
Old Jun 22, 2007 | 05:27 PM
  #259
Jeff_Jeske's Avatar
MB
You are right it will never hit 319. If you set it to 319 you are doing the same thing as running up the delay.
Maybe if you aren't monitoring your car and you run low boost you might want boost cut feature. I am running the car as hot as possible 24/7 with alchy. I dont want the car completely cutting out ever.
Old Jul 2, 2007 | 10:57 PM
  #260
AhBao9388's Avatar
hi im new to tis. can tis program work with the jdm evos? im thinkin of buyin the tactrix cable and do a copy on one of the pnp ecu that tomei has
Old Jul 4, 2007 | 05:03 PM
  #261
EVO8emUp's Avatar
When I open ECUFlash I get this in the task info box:
"[01:11:59.688] error loading FTChipID.DLL"
I'm not sure what to do from here.
Old Jul 4, 2007 | 05:06 PM
  #262
Mellon Racing's Avatar
a customer of mine ran into this.. I asked him to close all of his open programs/files and re-install ECUFlash and it worked fine.
Old Jul 4, 2007 | 05:41 PM
  #263
EVO8emUp's Avatar
Didn't work.
This is all i get in the task info box:
[00:18:40.461] Version 1.30.1095
[00:18:40.461] 8 memory models read.
[00:18:42.774] 145 ROM metadata models read.
[00:18:42.774] checksum module "subarudbw" loaded.
[00:18:42.774] flashing tool "wrx02" loaded.
[00:18:42.774] flashing tool "wrx04" loaded.
[00:18:42.774] flashing tool "sti04" loaded.
[00:18:42.774] flashing tool "sti05" loaded.
[00:18:42.774] flashing tool "mitsukernel" loaded.
[00:18:42.774] flashing tool "mitsukernelocp" loaded.
[00:18:42.774] flashing tool "mitsubootloader" loaded.
[00:18:42.824] error loading FTChipID.DLL
I'm stumped
Old Jul 4, 2007 | 08:44 PM
  #264
Evo_Pma's Avatar
one question if i want to change the stationary rev limiter what i should do? i just got my cable and i went to my evo 8 usdm and download the stock file made a copy a then change the stationary rev limiter to 5000rpm then upload it but i dont know what happend and didnt work , do i need to change anything else?
Old Jul 4, 2007 | 11:04 PM
  #265
Evo_Pma's Avatar
do i need to do this ? https://www.evolutionm.net/forums/sh...nary+rev+limit
Old Jul 4, 2007 | 11:46 PM
  #266
stikllr's Avatar
I need answers please,i just bought an ECU that was reflash and it has all the same mods installed on my car but i was wondering can i just plug that right in to my car or will i need like a code for it?
Old Jul 5, 2007 | 12:31 AM
  #267
Evo_Pma's Avatar
you need to copy the immobilizer code from your stock ecu
open ecuflash then options , user level change it to developer or advanced then close the program , open it again and then u can see the immobilizer code ( go to parameters, misc)
if u dont do this the car wont start because u dont have this code
hope this help u!
Old Jul 5, 2007 | 04:31 AM
  #268
cfdfireman1's Avatar
6000
How do you know it didn't work? By the way people that use this feature usually set the stationary rpm to 6000.
Old Jul 5, 2007 | 07:13 AM
  #269
sub7's Avatar
Didn't work.
I'm stumped
Locate the FTChipID.dll from your C:\Program Files\OpenECU\EcuFlash\drivers\x86 and copy it to C:\Windows\system32
Old Jul 5, 2007 | 08:06 AM
  #270
EVO8emUp's Avatar
It eliminated the error.
Task Info:
[18:19:07.046] Version 1.30.1095
[18:19:07.046] 8 memory models read.
[18:19:09.656] 145 ROM metadata models read.
[18:19:09.656] checksum module "subarudbw" loaded.
[18:19:09.656] flashing tool "wrx02" loaded.
[18:19:09.656] flashing tool "wrx04" loaded.
[18:19:09.656] flashing tool "sti04" loaded.
[18:19:09.656] flashing tool "sti05" loaded.
[18:19:09.656] flashing tool "mitsukernel" loaded.
[18:19:09.656] flashing tool "mitsukernelocp" loaded.
[18:19:09.656] flashing tool "mitsubootloader" loaded.
I think its fixed.
