MIVEC tuning
Old Nov 25, 2012 | 07:12 AM
  #751
donner's Avatar
Originally Posted by 211ratsbud
Doesn't seem to work for 8858 I get a solid 72
https://www.evolutionm.net/forums/8946095-post693.html
Old Nov 25, 2012 | 07:26 AM
  #752
211Ratsbud's Avatar
Looking for the map addresses already used that post. I'm getting a dip that I'd like I sort out
Old Nov 25, 2012 | 08:41 AM
  #753
JohnBradley's Avatar
It is old now, but there is a thread about logging MIVEC. Those are the correct addresses, the main thing is getting the formula correct.
aaron
Old Nov 25, 2012 | 08:52 AM
  #754
211Ratsbud's Avatar
Would the map formula match the actual formula? Similar to timing map and afr map matching ?
I log the actual mivec fine
https://www.evolutionm.net/forums/showthread.php?t=335226
Old Nov 25, 2012 | 09:39 AM
  #755
donner's Avatar
Ohh you are looking for target mivec addresses? For 8858 try 75DE and 75DF. Should match to actual mivec.
Old Nov 25, 2012 | 09:50 AM
  #756
211Ratsbud's Avatar
Thank you much! You haven't steered me wrong yet sir.
Old Dec 29, 2012 | 04:47 AM
  #757
kevin8086's Avatar
Wondering if someone has a fp red on 93 with S2 cams I could look at for mivec map. My car is tuned but the mivec map is stock
Old Dec 29, 2012 | 09:09 AM
  #758
211Ratsbud's Avatar
I would suggest JohnBradley's mivec map for S2 cams that he posted earlier. I think it will cover you. I use it unmodified. Albiet time consuming to enter manually.
Old Feb 12, 2013 | 07:42 PM
  #759
kevin8086's Avatar
So use the one that has advance all the way out to redline? I read a page or 2 back that 10* on mivec is actually 0 overlap. Is that true? So at 0* it would be retarded 10*?
Old Feb 13, 2013 | 07:30 PM
  #760
Well thats relative to an VIII and even then its a little different still. The cam timing for the IX swings from 0*-30* BTDC IVO on stock cams, an Evo 8 is 19* BTDC at "0".
Old Feb 13, 2013 | 09:22 PM
  #761
kevin8086's Avatar
So where "about" with a 9 on cossie M2 is 0 overlap. Also I have read that too much mivec will cause knock and that mivec will not cause knock. Is it usually better to back down mivec and use ignition timing or run aggressive mivec and lessen ign timing? I know every car is different but I'm having problems with not being able to run normal timing. 1-2* at peak tq and 7* at 7500
Old Feb 18, 2013 | 02:57 PM
  #762
evo10.5t's Avatar
Originally Posted by JohnBradley
Its funny how no matter what size motor, or how many cylinders, some things are constants. I have been building engines for 16 years and tuning EFI for 6, and it all comes back to common sense sometimes. Retarded cam at high RPM=The Loss.
Thanks for clearifying this!
Old Feb 18, 2013 | 03:40 PM
  #763
Actually that is backwards...it should have been advanced cam...what post is that so I can change that?
Old Feb 18, 2013 | 05:19 PM
  #764
evo8426's Avatar
Post 24
Old Feb 18, 2013 | 05:23 PM
  #765
Hi Im Vinh's Avatar
About to install S2s soon on my car , I will give your mivec map a try 211ratsbud! But what made you go back to JBs original S2 map?
