Ok I did my first logs
Old Nov 13, 2006 | 06:14 AM
Johnny Boy's Avatar
Originally Posted by TTP Engineering
That is not knock. That is motor torque and DP slamming on the crossmember when he shifts.
how can i fix that problem
Johnny Boy's Avatar
Originally Posted by C6C6CH3vo
Car appears fast from the logs (too fast for mods) but sampling needs to improve (follow TTP inst) to tell
Thanks
Old Nov 13, 2006 | 06:17 AM
TTP Engineering's Avatar
1. Buy a new DP that fits
2. Remove your crossmember altogether
3. Add spacers or washers with longer bolts
Old Nov 13, 2006 | 06:27 AM
Johnny Boy's Avatar
would #3 affect the handling of the car and what DP fits perfect
Old Nov 13, 2006 | 06:39 AM
bboypuertoroc's Avatar
Veteran: Army
#3 shouldn't effect anything but your knock count (if that's what's causing it)... I need to do the same thing.
Thanks for the tip TTP... I'll be doing that on Sunday while I'm dynoing... also removing the bars for that.
Old Nov 13, 2006 | 06:52 AM
MalibuJack's Avatar
I used an engine torque damper on another car that had a rattling downpipe, it helped his car when the car would torque itself, the engine would shift and the downpipe would make contact with the crossmember.. adding the damper stopped the engine from shifting as much and his knock issue went away.. I'm going to try the same thing on my car, plus wrap the downpipe with thermal wrap to insulate it from metal to metal contact.. On his car, it also improved his missed shifts from the binding he was experiencing.
I'd stay away from solid mounts or firm motor mounts simply because it may stop the engine from shifting, but possibly make other noises transmit into the engine..
I put spacers on my tie bar, it was required with the earlier buschur downpipe, but even that wasn't enough to prevent the contact.. When I have some time I'm going to adjust my turbo outlet on the GT35r to see if I can get it to tuck the downpipe up a bit more while I'm under there.
Old Nov 13, 2006 | 09:38 AM
RyanCGTP's Avatar
1* KR under WOT in some frames , every thing else seems like false KR .
Scan looks good
Old Nov 15, 2006 | 07:14 PM
wrcwannabe's Avatar
Yep 0-3 is fine . Fix the DP issue and you're good to go.
Milburn
Old Nov 16, 2006 | 07:18 PM
sekula's Avatar
hey guys, i got evoscan recently, and can i view these logs on evoscan and if yes how, cuz i can only view them in excel right now
jakgal04
Jun 1, 2016 10:55 AM
damie45
Apr 5, 2011 11:28 AM
wtf_is_a_evo
May 1, 2010 11:04 PM
evil mechanic
Jan 8, 2007 12:36 PM
Dapper Dan
Aug 29, 2006 11:21 AM
