JDM Evo IX MAP sensor group buy
Old May 29, 2007 | 06:13 PM
  #316
nj1266's Avatar
Originally Posted by RedV
So of course I was like, "Great, what just broke on the way to the track?" When I got the track I used my laptop and cable to check the code, "P0401: Exhaust Gas Recirculation Flow Insufficient".
Thanks
The code that your ECU threw is emissions related. I doubt that it has something to do with the proper running of the car. I have yet to throw a code with my JDM MAP sensor. I am sure that mrfred will figure a cure for this.
Old May 29, 2007 | 06:53 PM
  #317
Tuner@Swift's Avatar
I was getting the same code before I installed the JDM map sensor. The EGR hoses were still attached, so I just disabled the test for it. I think i was due to not having the Baro sensor hooked up.
Old May 29, 2007 | 07:31 PM
  #318
RedV's Avatar
Yeah I figured "mrfred" will eventually come up with something. I just was hoping it had already been fixed and I had just missed it.
I got under my car tonight just to verify that all of my EGR lines were still connected properly, as I've read that some people have had them pop off and this could throw the same code. But all of my EGR lines appear to be connected and just fine. The car has ~13,500 miles on it right now so it's still fairly new.
If this code keeps popping up more frequently then I might have to switch back to the USDM sensor. But if it only occurs once a month or so (since it's been about a month since I first installed my sensor), then I can just keep clearing it and wait for a fix.
Thanks for the feedback guys!
Old May 29, 2007 | 08:06 PM
  #319
mrfred's Avatar
I am indeed working to find a fix. I have learned enough assembly language to be able to find some 1D MAP sensor comparison tables that were previously overlooked. I don't think they are related to a P0401 code though. Give me a week or so to further analyze the code.
Old Apr 30, 2008 | 10:45 AM
  #320
mitsuatb's Avatar
EGR test
If this is to basic, sorry about that, but if not it might be helpful.
On my old Z28 EGR tests also crop up as CEL's.
The way they work is to switch on the EGR and look for the drop of manifold pressure sensed by the MAP sensor. If they don't see the drop, then they throw the code.
Since the 3bar has a different output in pressure/volt , the ECU may not be getting the pressure drop signal it expects to see and throwing a code.
As an example, I had a bad map sensor, and I kept getting egr codes on the Z28, changed the MAP sensor and no further problems.
I wish I knew how to change the code, and test my theory, but I don't have a clue.
Mitsuatb
mrfred
Jan 28, 2017 09:58 PM
joedr
Sep 29, 2009 10:53 AM
NeoGearX
Aug 16, 2009 06:36 AM
Speed Element
Jul 2, 2009 03:09 PM
Speed Element
Feb 24, 2009 05:11 PM
