ECUFlash / Evoscan / Mitsulogger Questions
Old Aug 9, 2011 | 05:55 PM
  #1021
dparrish's Avatar
You have probably messed up the immobilizer code. Do you still have the backup ROM you read from the car before you flashed a new one? If you open that up in EcuFlash there's an "Immobilizer Code" table which you need to copy to the new ROM and re-flash it.
If you didn't make a backup... well.. you should have read the guides on how to do it first!
Luckily if you absolutely need to you can disable the immobilizer completely, but that will let someone start the car with a screwdriver.
Old Aug 9, 2011 | 06:19 PM
  #1022
403VO's Avatar
No, didn't back up anything because i thought it was useless anyways.. I just wanted my car to run like a stock EVO. My key didn't have a chip built into it AFAIK...
How do i disable the immobililzer? Can i enable it somehow after i hear how it's running? Or can i just get the immobilzer code from the dealership?
Old Aug 9, 2011 | 06:25 PM
  #1023
dparrish's Avatar
Open up the rom in EcuFlash, look down the bottom of the list of tables for "ECU Periphery0 (FAA) Bits". That table contains 16 options which may or may not be labelled. You need to change the 4th from the bottom from 1 to 0. If you don't have the "ECU Periphery 0 (FAA) Bits" table, you may have one just labelled "ECU Periphery0 Hex". If you just have that one, give me the single value in that table which will probably look like 52D8 or something close.
Old Aug 9, 2011 | 06:43 PM
  #1024
403VO's Avatar
"Disable EGR / Enabled Ign Adv (set bit=0)
timing knockdown on light acceleration and less than 3000rpm
Enable Warmup Ign Retard
bit.8
Enable High Oct Ign Map Lookup (and many other subroutines)
"WG solenoid? Enable Speed Limit Test"
bit.5
for full time open loop set to 0
Immobilizer (1=enable 0=disable)
bit.2"
Like that?
EDIT: They are all grey'd out.. I can't open them unless i right click 'edit map'
Attached Thumbnails ECUFlash / Evoscan / Mitsulogger Questions-immob.jpg
Old Aug 9, 2011 | 06:50 PM
  #1025
dparrish's Avatar
Yes, that's the table. Change the immobilizer one to 0, re-flash and the car should start again.
I don't know of any way to get the immobilizer code again once you've lost it.
Old Aug 9, 2011 | 06:58 PM
  #1026
403VO's Avatar
Changed it to 0, re-flashed, still won't start.
Old Aug 9, 2011 | 07:09 PM
  #1027
dparrish's Avatar
Does it turn over and die a couple of seconds after it starts or does it sound like it's not firing at all and just using the starter motor? Or does it just click when you turn the ignition key?
It may be that the immobilizer cut is incorrectly labelled on your ROM, I have no idea if it works or not. I know that I have done the same thing on a Tephra 96530706 rom and that worked (I initially had trouble copying across the immobilizer code). You *could* try that. You can get the rom and XML definitions from https://www.evolutionm.net/forums/ec...hramod-v7.html
I'd give the 96530706 ROM a go rather than the others because this one is closer to a "universal" evo 7/8 ROM. This is probably getting a bit more involved than I would have suggested for a complete newbie to ecuflash, but having not taken a backup you're going to have to dive right in to get it fixed.
What I can say is that you haven't irreversibly messed it up, but it's going to take some work to get it fixed.
Old Aug 9, 2011 | 07:20 PM
  #1028
403VO's Avatar
Not firing at all, just using starter motor..
What frustrates me the most is how a supposed stock OEM ROM is not working even with the Immobilizer disabled..Leads me to think i might of screwed up something even before i flashed it by replacing the orig. .xml files in the rommetadata\mitsubishi\evo directory...
Old Aug 9, 2011 | 07:36 PM
  #1029
403VO's Avatar
I think i've been doin something totally wrong here from start..
I just download the 96530706-TephraMod an it came as a compressed folder with 2 files in it. 1 of them was a bin file an the other was a xml doc...
I moved the xml file into the rommetadata\mitsubishi\evo folder and then moved the ROM file to my desktop..
I try to open the ROM file an get that damn 'Unknown ROM image' prompt again!!! Where am i suppose to move the Rom file?
Old Aug 9, 2011 | 08:16 PM
  #1030
dparrish's Avatar
The XML files control how EcuFlash modifies the ROM image. You can open up a ROM image without the appropriate XML files, follow through the wizard so that it opens up (with no useful definition) and write it to the ECU. That bit will work fine. You just need the XML files so you can make some modifications to the ROM before you write it.
The tephra XML requires 96530006.xml to be available too. I've attached it here, download it, rename it to 96530006.xml (it's .txt now) and save it to your rommetadata\mitsubishi\evo directory. Then close ecuflash and try to open the tephra ROM again.
File Type: txt
Old Aug 10, 2011 | 05:18 PM
  #1031
403VO's Avatar
So i got the immobilizer code from a buddy who works at the mitsubishi dealership so that problem is fixed..phew! But I can't seem to change the txt file into .xml file. I renamed it but when i right-click an go to properties, it still shows it as a txt file... Can you just upload the xml version of it?
Edit: NVM, under folder options, it was hiding extension...
So i did tryed to change it but it says there is an existing file already with that name.
Old Aug 10, 2011 | 05:23 PM
  #1032
dparrish's Avatar
This forum won't let you upload .xml files.
Just grab the appropriate XML file from http://www.evoscan.com/roms/mitsubishi/
Old Aug 10, 2011 | 05:40 PM
  #1033
403VO's Avatar
Alright so now when i open ROM, after replacing the existing file with the same name(96530006.xml) in the rommetadata/evo directory... ECUflash just crashes.
Old Aug 10, 2011 | 05:50 PM
  #1034
403VO's Avatar
I have a feeling it's this stupid BETA version of ECUflash that is giving me all the issues. Is there a list of all the previous versions of ECUflash from reliable sources. Can't find it on Evoscan website...
Old Aug 10, 2011 | 05:53 PM
  #1035
dparrish's Avatar
http://code.google.com/p/ecurom/sour...ols%2FEcuFlash has lots of older versions.
