ECUFlash / Evoscan / Mitsulogger Questions
Old Jun 7, 2012 | 02:02 PM
  #1246
Jhutterer's Avatar
Originally Posted by bsh
Evoscan and a USDM 2003 Evo 8.
I am completely new at this so be gentle. I just purchased Tactrix OP2.0 and installed the latest v2.9.0021 software. It seems like I cant display DTCs or log. At the received Data/Eventlog window I get:
Info: OpenPort 2.0 found
Info: OpenPort firmware v1.11.320
Info: Battery 12,134V
Info: initalize vehicle ecu...
Info: OBDII connecting...
Info: Initializing at 5 baud...
info: Initializing complete...
Info: No response from Vehicle ecu
Info: check DTCs complete.
I have tried Openport 1.3x and 2.0, OBDII 96+ and Mitsubishi MUTIII at device setup.
I also choose the OBDII EFI (all 1996-2006 i.e. Evo7/8/9)
Anyone have any idea what I have done wrong?
Thanks
I don't know how "new" you are but did you have the ignition turned to on, so the ECU has power? Of course the engine should not be on just radio lights and all that.
It looks like the ecu isn't responding.
Old Jun 7, 2012 | 11:12 PM
  #1247
bsh's Avatar
bsh
Thanks
When I say I am completely new, it means I installed EvoScan on my laptop yesterday
Ignition was on...
I borrowed a universal OBDII reader from a friend a the local Mitsubishi dealership a month ago to clear DTC, and that device worked fine.
Anyone?
Old Jun 20, 2012 | 07:46 AM
  #1248
babaz7's Avatar
hi why isnt evoscan correctly reading my loadmut2byte mod?
instead of reading say from 0 to 300 depending on your load mine is reading 2741 something?
plz help as i have been asking this question in another thread i created but no one seems to bother to reply!
Old Jun 25, 2012 | 07:27 PM
  #1249
EVOMIZ's Avatar
so how can I get the ecunavi to dispaly boost in a evo 8?
Old Jul 5, 2012 | 02:19 PM
  #1250
FLASH1970's Avatar
I have a problem with my LC-1/XD-16 setup. It was working fine, then I recalibrated through EVOScan (version 2.8) and it messed up my gauge. The gauge now reads between 4.1 and 6.4. I went for a cruise and had Logworks up and on the computer screen it showed 13.3-14.1 while the gauge showed 5.8-6.2. If I let off the gas while cruising the gauge says 20.0/o2 (typical fuel cutoff when above a certain rpm) and if I floor it the gauge reads around 4.4 while Logworks shows about a 10.5:1 afr. I already made sure the fuel was on gasoline. I tried disconnecting the car battery to reset everything. I tried recalibrating the unit a few times. I tried disconnecting the gauge from the LC-1 and reconnecting it. I have the LC-1 connected to the gauge IN port, then I have the serial cable connected to the OUT port on the gauge and I plug that into my laptop to log my AFR. Any ideas on how to fix this? Thanks for your help in advance.
Flash
Old Jul 6, 2012 | 01:41 PM
  #1251
evoscan's Avatar
Silver Sponsor
Flash
Yes, this is a well documented fault with all the LC1 widebands, and is why we all use zeitronix or aem gauges. it is written on my wideband review on the EvoScan website. evoScan issues the standard recalibrate command. the same as the logworks does. The LC1 calibration annoys me, its a pain and never works properly. and the LC1 resets its internally memory when you least expect it or when your battery goes flat. just recalibrate again using either evoscan or logworks, both are the same. LC1 uses a software calibration, whereas the AEM and ZTX uses a hardware factory calibrated resistor calibration.. I know which one I prefer.
Old Jul 6, 2012 | 04:24 PM
  #1252
EVOMIZ's Avatar
Ne1
Old Jul 7, 2012 | 12:28 AM
  #1253
jedibow's Avatar
Need some help, attempting to flash a friends car, Rom pulls fine, ID 96940011, when I attepmt to open the fuel tables Ecuflash states that it has encountered a problem and needs to close????
If you know what is wrong let me know, however could I just flash over the 94170015 ROM that I have completely defined, and transfer the immobilizer code?
Thanks
Old Jul 9, 2012 | 09:33 AM
  #1254
FLASH1970's Avatar
Just to update my problem, the person from Innovative said to use the LM Programmer software, Not Logworks, to reset everything to gasoline. I'll post back if this fixes it.
So I opened up LM Programmer on my laptop with the unit connected via serial cable/usb converter plug, key on, car not running so the unit would power up, reset it to gasoline, and it works again. The display matches what's showing up in EVOScan.
Old Jul 11, 2012 | 07:46 PM
  #1255
drag4life723's Avatar
Thanks
Have the same issue here. Car runs great i can flash and datalog all day no issue. Solid CEL that never goes off from start up. Even if i re flash it or pull the battery. Tried scaning it with EvoScan i get this error. I have also tried normal scan tools and none of then will communicate.
Thanks
Russ
Old Jul 15, 2012 | 04:16 AM
  #1256
efekhs's Avatar
hi all
please how to now ecu identification number exm (99860002)
Old Jul 19, 2012 | 08:37 PM
  #1257
mugsy's Avatar
have an odd issue with logging ecu. when car is off evoscan will connect and show proper throttle/battery voltage but when i go to start the car it starts to show readings then disconnects and cannot get it to connect when running. 1.3 cable btw
Old Jul 29, 2012 | 09:25 PM
  #1258
waskarn's Avatar
MMC not work
I bought MMC Flash USB Module#1 from limitless.
First time when I plug in to my computer(XP) it's not response but have red light form MMC. I test plug in to Note book (win7) it's not work.
Old Jul 30, 2012 | 08:45 AM
  #1259
evoscan's Avatar
Silver Sponsor
You need to install the mmcflash software first, that I just emailed you today.
Cheers.
Hamish.
Old Jul 31, 2012 | 06:43 AM
  #1260
ihockey1's Avatar
alright i know this has been asked but i cant find where, what is the zeitronix boost formula for evoscan so that it reads correctly
