ECUFlash / Evoscan / Mitsulogger Questions
Old Dec 8, 2012 | 09:27 PM
  #1321
dtrackstar's Avatar
Originally Posted by salt36
You can copy the dll from the Ecuflash folder and paste it in the Windows Sytem32 folder.
Find it here; C:/Programfiles/OpenECU/EcuFlash/drivers/openport 1.3/i386
If you have Windows7 it will be in the Programfiles(x86) directory.
If using Windows7 you will also need to copy the dll into the C:/Windows/sysWOW64 folder
Thanks for your help!!! Works perfectly.
Now, I have another question. My car was previously tuned using tephra 5 or 6 and I "read from the ECU." When I use evoscan, everything (JDM Map, etc) are working except for 1 byte load. 1 byte load was reading 0 and then i changed the mut table (4,1) based on other instructions here and now it reads 72 across the board. Do I still need to download a tephra patch to be able to read 1 byte load?
If I do, then what happens to my current map, etc. Any help woud be greatly appreciated.
Thank you!
Old Dec 9, 2012 | 01:23 AM
  #1322
Lancer_Evo_8's Avatar
Maybe someone know this problem. I can not connect my EVOscan with my Laptop. 10 Days ago it was working perfectly, I didnt changed something. But now i get this weird pict here:
Old Dec 9, 2012 | 10:33 AM
  #1323
03lances's Avatar
Assuming you are using a openPort 2.0 cable I would suggest trying to reinstall the drivers to see if that fixes the issue.
Old Dec 9, 2012 | 11:28 AM
  #1324
salt36's Avatar
Thank you!
Sorry I can't help you with this, hopefully someone else can.....
Old Dec 9, 2012 | 11:59 AM
  #1325
I already re-installed onetime the whole EVOscan. Onetime i did the same with just drivers. But nothing changed.
Old Dec 10, 2012 | 11:28 AM
  #1326
salt36's Avatar
Have you changed or updated your virus scanner?
Sometimes these will interfere....
Old Dec 11, 2012 | 07:29 AM
  #1327
I toke some ticket at the EVOscan Homepage. So today he helped me with the teamviewer. But i dont know what he changed. But know it work again.
Old Dec 13, 2012 | 01:39 PM
  #1328
BayAreaCT9's Avatar
disconnecting from ecu
is there a certain sequence to disconnect tactrix from the car after upload of the rom? i tried searching and reading merlins guide .. turn car off then just disconnect from it ??
Old Dec 13, 2012 | 01:45 PM
  #1329
Macaroni's Avatar
I just unhook it even if the key is still on. As long as you don't unplug it while reading the ecu or flashing you should be fine.
Old Dec 13, 2012 | 02:11 PM
  #1330
BayAreaCT9's Avatar
thanks !
Old Dec 13, 2012 | 05:08 PM
  #1331
Sir2egk's Avatar
Hopefully this can be answered
so i have an aem 60psi boost gauge with of course the 5 bar map sensor.
now my car is currently on the omni 4 bar and im moving up to 5 bar. is there anyway i can use the two leads from gauge (RS232(blue wire), 0-5v output(white wire)) to hook up to the oem map plug? i really dont want to purchase another 5 bar map sensor.
hopefully you can understand what im trying to say. thanks
also if i do it this way on stock ecu and then later on i switch to a stand alone ecu will it still function
thanks
Old Dec 27, 2012 | 07:09 PM
  #1332
pete228's Avatar
evoscan and tactix 2.0 cable issues
I am having a disconnecting problem with evoscan 2.9 and tactrix 2.0 cable. connected and datalogs for a few minutes, then disconnects with a error message stating i have to unplug the usb. Is there any settings to make this work? i just went through all the options til i found on that would allow it to connect. I been searching all day and cant find a recent info on this and evoscan support is not responding back to my questions.
Old Dec 28, 2012 | 03:18 AM
  #1333
evoscan's Avatar
Silver Sponsor
upgrade to the latest v2.9.0023 and select disable multithreading from the logging menu. turn off any hdd protection systems by your laptop, ensure that the usb plug is secure when you go over bumps. try a different usb port for a try, and/or try another mini usb cable too.
Old Dec 28, 2012 | 04:59 AM
  #1334
pete228's Avatar
Ill give that a try. I dont think hard drive protection is a problem. as it does the connectivity issue when sitting at idle. What settings should i be using for 2.0 cable and evo 8? mutIII and efi? i was selecting evo5,6 under the ecu settings and it logs for a few minutes before it disconnects.
Old Dec 28, 2012 | 08:18 AM
  #1335
pete228's Avatar
I tried what you suggested. I figure it out. i used a com port cleaner reopened evo scan and plug the usb back in and its working fine now. So that might be a issue people are having with evo scan not staying connected.
thanks
