log boost with JDM MAP sensor (updated instructions)
Old Nov 20, 2007 | 08:08 PM
  #361
mrfred's Avatar
Absolute pressure is what matters, but most everyone is used to thinking in psig.
Old Nov 20, 2007 | 08:43 PM
  #362
GTLocke13's Avatar
But this means that your JDM MAP sensor boost control mod is the right way to control boost. Its looking at absolute, not gauge.
Old Nov 20, 2007 | 08:49 PM
  #363
mrfred's Avatar
Load also scales roughly with absolute pressure. Both methods can work. Just depends on whether you want to set load targets or boost targets.
Old Nov 20, 2007 | 08:55 PM
  #364
Evo_Jay's Avatar
look at post 341
Old Nov 21, 2007 | 09:50 AM
  #365
GTLocke13's Avatar
That was the post that got me thinking about all this. My point is you don't have to do that. The controller is controlling to absolute pressure. If you set your boost to 20 psi and your boost adder to 14.7 psia, the controller is controlling to 34.7 psia. If the ambient pressure is 10.7 psia, the controller will control to 24 lbs of boost, but this is fine because its the 34.7 psia that matters to the motor. In this case, 24 lbs of boost is not overboost.
I think the boost correction works to the psia value, not the psig value.
Old Nov 21, 2007 | 01:28 PM
  #366
mrfred's Avatar
All correct.
Old Nov 21, 2007 | 07:35 PM
  #367
Evo_Jay's Avatar
Yeah. i just went to 5000ft elevation the other day and my boost was 2.5lbs higher. Perfect curve and correction still.
Also the car didnt knock or anything. I didnt log but I have the CEL on knock patch.
Old Nov 21, 2007 | 10:57 PM
  #368
GTLocke13's Avatar
That sounds dead on. Pressure at 5000 ft is about 12.2 psia.
http://www.uigi.com/Atmos_pressure.html
Old Dec 31, 2007 | 11:32 AM
  #369
mrfred's Avatar
Just wanted to mention that I have a few JDM MAP sensors available. See first post for details.
Old Dec 31, 2007 | 11:38 AM
  #370
cij911's Avatar
Is it possible to use the JDM MAP sensor to replace the MAF unit? Sorry if this was addressed earlier.
Old Dec 31, 2007 | 11:41 AM
  #371
mrfred's Avatar
Only if you intend to switch over to speed density (MAF no longer needed).
Old Dec 31, 2007 | 11:42 AM
  #372
cij911's Avatar
Yes, I would be interested in seeing the pros vs cons with speed density on the stock ecu (and the how tos) Thanks
Old Dec 31, 2007 | 11:52 AM
  #373
mrfred's Avatar
Its a complicated patch, so there is no "how-to", and there are no base ROMs with a patch pre-applied. From what I've seen, there's no obvious advantage to speed density.
Old Dec 31, 2007 | 11:56 AM
  #374
cij911's Avatar
What advantages do you see using MAP to control boost instead of load?
Old Dec 31, 2007 | 01:16 PM
  #375
mrfred's Avatar
Load and boost do not track perfectly with each other on Evos. In higher gears, the car will boost higher for a set load. I prefer to control boost directly rather than load.
