log boost with JDM MAP sensor (updated instructions)
Old Feb 11, 2008 | 05:26 PM
  #421
RazorLab's Avatar
Originally Posted by mrfred
Yeah, in ECUFlash its the scaling applied to the data in the ROM.
Temperature scaling -> 85C
WGDC scaling -> 63%
I'm not sure I am following you. When I switch it to WGduty scaling it goes to 0.0%
Old Feb 11, 2008 | 06:04 PM
  #422
voidhawk's Avatar
Originally Posted by tephra
what does it log when no throttle?
you probably need to adjust the angle of the TPS sensor, not sure how.. probably some alignment bolts someplace
It reads 5.4 when no throttle, so it's not just a straight offset (since then it would read -4, right?)
Old Feb 11, 2008 | 06:37 PM
  #423
tephra's Avatar
on mine and many others
no throttle = 12% to 13%
full throttle = 100%
sounds like you need to adjust the sensor
Old Feb 11, 2008 | 07:41 PM
  #424
mrfred's Avatar
You got the right idea. It should read 63%. The problem is that the WGduty scaling assumes the value is uint8, but its uint16. I forgot about that. If you change the address to 0x1e27, then you'll get 62.5%.
Old Feb 11, 2008 | 07:58 PM
  #425
RazorLab's Avatar
That worked. Thanks.
Old Feb 11, 2008 | 08:09 PM
  #426
Tek3Evo's Avatar
also a Max WGDC Correction table that looks like this:
0 TP - 0 correction
13 TP - 0 correction
25 TP - 0 correction
38 TP - 0 correction
50 TP - 0 correction
63 TP - 0 correction
75 TP - 0 correction
88 TP - 16 correction
100 TP - 16 correction
Are these changeable values? can correction go beyond 16% if changed to a higher value?
Old Feb 11, 2008 | 08:12 PM
  #427
RazorLab's Avatar
I haven't tested it yet. I would imagine so.. would need to do some logging.
Old Feb 12, 2008 | 09:04 PM
  #428
300477's Avatar
Guys,
I have just added the "ROM Mods for 2004 USDM Evo 8 ROMs 96420007, 96420008" to my 96530006 xml file and all the values have come up correctly.
Is it save to assume that the 96530006 is in the same family of ROMs as: ROM96420007, 96420008? If the "MAP" maps are located in the same spots?
  #429
300477's Avatar
Double post
Old Feb 12, 2008 | 09:14 PM
  #430
tephra's Avatar
Hey Shane,
What are you trying to accomplish?
Does your 8 have a JDM MAP? or any map?
Cheers
D.
Old Feb 12, 2008 | 09:30 PM
  #431
300477's Avatar
Hey Shane,
Cheers
D.
I can get my hands on a JDM map sensor.
What i really want is the ability to run without an AFM. So looking at the JDM map sensor seems like a good start.
Old Feb 12, 2008 | 09:34 PM
  #432
mrfred's Avatar
ok, but does your car have a factory MAP sensor now? Where are you located?
Old Feb 12, 2008 | 09:43 PM
  #433
300477's Avatar
At this stage no it doesn't, but I have 1 in some of the spares i have, it would just be a matter of installing it.
Im located in Australia.
Old Feb 12, 2008 | 10:34 PM
  #434
mrfred's Avatar
You're car doesn't have factory wiring for a MAP sensor, but we've figured out enough to be able to install a MAP sensor on any Evo now and allow the ECU to read and use the data. The install isn't much harder than installing a gauge, but the ECU mods are something that I haven't bothered with yet because I mainly deal with the USDM crowd. tephra is working out boost sensor reading for his ECU though.
Old Feb 12, 2008 | 11:16 PM
  #435
300477's Avatar
The wiring isn't really a problem, i can just pinch the loom from a wreak, and connect up the correct pin to the ecu. After that ill try out evoscan and make sure its reading correctly. Ill get the sensor and wiring this weekend, and hopefully fit it up next weekend, depending on how hard it is to drill out the manifold.
