log boost with JDM MAP sensor (updated instructions)
Old Apr 21, 2008 | 10:00 PM
  #481
Inprogress's Avatar
That setting was changed and I still got errors. I even put in an old map that hadn't ever been touched and it still died.
Old Apr 21, 2008 | 11:46 PM
  #482
Inprogress's Avatar
Anyone? Sorry if I seem pushy, I'm just a little worried.
Old Apr 22, 2008 | 07:19 AM
  #483
mrfred's Avatar
You've uploaded the changed ROM to your ECU, correct? Sorry if I'm asking the obvious, but need to be sure. If yes, then PM me, and I'll have you email me your ROM.
Old Apr 22, 2008 | 07:59 AM
  #484
Inprogress's Avatar
by rom do you mean the map? No, I flashed my car with the same original map just with the US map settings instead of the jdm map settings when I put the US map back in.
Is this normal mrfred?
Old Apr 22, 2008 | 08:46 AM
  #485
mrfred's Avatar
The ROM is what gets uploaded to the ECU using ECUFlash. Its the "program" that the ECU runs. The maps are in the ROM.
Old Apr 22, 2008 | 09:02 AM
  #486
Inprogress's Avatar
Oh so you're referring to the fiile in the folder named rommetadata in ecuflash folder right titled 88590015?
Do you mind if I send you my map and rommetadata file 88590015?
Old Apr 22, 2008 | 09:03 AM
  #487
scheides's Avatar
EvoM Moderator
Originally Posted by scheides
Having trouble getting this to work with 96530006 (euro 2005 rom). I used the code for the 2005 USDM ROM (96940011) and came out with this:
Any idea how to get this to work?
Update, logging boost *just works* with 96530006.
Old Apr 22, 2008 | 09:27 AM
  #488
mrfred's Avatar
Seems like we're getting tied up on nomenclature:
ROM: This is the file that is uploaded/downloaded from the ECU. The ROM file has all the maps, and ECUFlash is used to modify the maps in this file.
88590015.xml: This file contains the addresses of all the known maps in the ROM file. Its a guide that ECUFlash uses to display the maps in the ROM. The 88590015.xml file is not uploaded or downloaded from the ECU.
I'm sure what's happening in your situation is that one of the tables got overlooked when you were converting back to stock values. Probably best solution is for you to send me your ROM file. I'll PM you know with my email address.
Old Apr 22, 2008 | 09:40 AM
  #489
Inprogress's Avatar
I see. I'll send the rom this afternoon. Thanks MrFred!
Old Apr 22, 2008 | 07:12 PM
  #490
Mr Evolution's Avatar
Got it resolved, It was the battery was low and had pretty much trickle charge it back to start the car. I have a mini battery and the Evo is not driven very often. Guess will leave the trickle charger on all the time now.
Thanks to all those that made all the suggestions. Especially mrfred for making this mod as simple as writing this post.
Old May 24, 2008 | 04:52 PM
  #491
MR Turco's Avatar
I am setting this up for a friend running the 96420007 rom. Do we need to change the MAP test 2 value, if not can you just say it can be left alone? Also the MAP test 4 value was 1.50 not 1.80.
Old May 24, 2008 | 07:47 PM
  #492
mrfred's Avatar
If the instructions don't ask for it to be changed (yes, I've forgotten exactly what I wrote) then its ok to leave it. :-)
Old May 25, 2008 | 07:51 AM
  #493
Evo8Emperor's Avatar
A quick question for you mr. fred. By any chance would you know off your head what your jdm map sensor reads at idle for vacuum ?
Thanks again for all your work and help. I had no problems with your directions just read and then re-read to make sure. Everything works fine it seems.
Old May 25, 2008 | 09:51 AM
  #494
mrfred's Avatar
-8 to -9 psi is typical.
Old May 25, 2008 | 11:06 AM
  #495
ahh ty. hmm i usually see about -5 psi vac on idle. not sure if its because of my rich idle problem but im sure theres no boost leaks.
I believe I have a bad maf and a very cool evom member by the name of mixmastermatt offered to come by with a good maf swap it in and help me figure out my problem. It was some good news for once and i appreciate it a lot.
