OEM Style Gauges for EvoScan .99
Old Apr 2, 2007 | 04:16 PM
TouringBubble's Avatar
OEM Styled Gauges for EvoScan .99 (v.002)
Download Left Side
This file includes:
Speedometer (MPH + KM/h)
3-stage Speed Warning Indicator (80, 100, 110)
Tachometer
2-stage STi-styled Shift Light (6k, 7k)
AFR Display
AFR Indicator Lights for Open Loop Operation
Closed Loop Indicator
Download Right Side
This file includes:
Coolant Temp
TPS
Full Throttle Indicator (95% - 100%)
Boost (for JDM MAP)
Knock Count
3-stage Knock Indicator
Load
Timing Advance
Octane
Intake Air Temp
Injector Duty Cycle
Mapping Info:
Speedometer - Speed
Speed Warning Indicator - Speed
Tachometer - Engine RPM
Shift Light - Engine RPM
AFR Display - Wideband AFR (Wideband O2 sensor required)
AFR Indicator Lights - Wideband AFR (Wideband O2 sensor required)
Closed Loop Indicator - O2 Feedback Trim
Coolant Temp - Coolant Temp
TPS - Throttle Position
Full Throttle Indicator - Throttle Position
Boost - JDM MAP (Instructions Here)
Knock Count - Knock Sum
Knock Indicator - Knock Sum
Load - Calculated Load OR 2-Byte Load
Timing Advance - Timing Advance
Octane - Octane Level
Intake Air Temp - Air Temperature
Injector Duty Cycle - Must add IDC% formula to data.xml file (Formula found here)
Here is a layout file with values already assigned.
Instructions:
1. Download the left and right side XML files above using the right-click > Save As... method.
2. Save the files in your "EvoScan v0.99/GaugeTemplates" directory.
3. If you want to use the provided layout file, download the layout XML file to the "EvoScan v0.99/GaugeLayouts" directory.
3 a. To load the provided gauge layout, select "Gauges > Load / Display Gauge Layout" from the EvoScan menu and select the layout you've downloaded (i.e. oemGauges_002).
4. Open EvoScan.
5. From the top menu, select "Gauges > Add/Edit Gauge Widgets."
6. From the pulldown menu in the new window, select one of the new gauge files you've downloaded (i.e. OEMitsuGaugesLeft)
7. Assign the input values as noted above by right-clicking the image of the gauges.
8. If you would like to re-size the gauges, click and drag the lower-right corner of the window until they are the desired size.
9. When you are done, click the "Create New Widget" button at the bottom of the window.
10. You can move the gauges around by clicking and dragging the gauge window. you can also change assigned input values or close the gauge widget from the right-click menu.
11. To save the layout you've set up, including all of the mapped input values, select "Gauges > Save Current Gauge Layout" from the EvoScan menu.
Enjoy.
Andenbre's Combined Versions:
OEM Style
eBay Blue
RalliArt White
Last edited by TouringBubble; Sep 18, 2007 at 07:10 AM. Reason: Added Andenbre links
Old Apr 2, 2007 | 04:38 PM
Evo_Jay's Avatar
Good Job.
People are gonna love these
Old Apr 2, 2007 | 04:42 PM
RedV's Avatar
YAY!! I'm one of the (probably thousands of) people who PMd you about these earlier. THANKS!!
Old Apr 2, 2007 | 04:47 PM
laakness's Avatar
Very nice work.
I'll have to look at the xml cause it looks like you were able to get the gauges close without having the background overlap/intersect the others.
Old Apr 2, 2007 | 04:51 PM
How you see them is very close to how I put them together. I resized them a bit before dropping them on the desktop, so they are a little off. If you try to resize too much, they will try to overlap ...
Old Apr 2, 2007 | 04:59 PM
sikrsix's Avatar
I put the layout in the gauge layout folder and the left and right side into the gauge templates.. But it comes up as an error.. I tried swapping them into the opposite folders and got errors as well.. which goes where?
Is this cuz I still using 0.97?
Old Apr 2, 2007 | 05:00 PM
It could be because of .97, I'm not sure. The left and right files go in the templates folder and the oemGauges.xml goes in the layouts folder. You have it right.
Old Apr 2, 2007 | 05:03 PM
sikrsix's Avatar
Ya I thought so.. I have other gauge layouts and they work fine... hmmmm anyone still using 0.97 and this works?
Old Apr 2, 2007 | 05:05 PM
VenomEVO8's Avatar
Gauges work... but I can't resize them? anyway I can tweak it to make it smaller
Old Apr 2, 2007 | 05:09 PM
You will not be able to resize them from the layout file provided. You have to resize them from the "Add Gauges" window, so you'll have to make all of the associations again. No big deal though.
Old Apr 2, 2007 | 05:14 PM
VenomEVO8's Avatar
Cool.. thanks..
Old Apr 2, 2007 | 05:26 PM
16vEVOIX's Avatar
Thanks. I was just thinking about gauges like these, but didn't know how to make them.
Old Apr 7, 2007 | 12:22 PM
recompile's Avatar
Well done. Thanks!
Old Apr 7, 2007 | 02:13 PM
jdmevo8313's Avatar
Registered User
I downloaded both templates and the layout but when I load the gauges only the left side would open.
Yes I do have v.99
Old Apr 7, 2007 | 02:17 PM
evo 8 ya's Avatar
great work man
