What is the max load are u seeing guys?
Old May 5, 2009 | 01:58 PM
  #181
jcsbanks's Avatar
Peak load is far more related to peak torque than peak power, and there isn't really any decent comparison to be made depending on the differences between physical MAF arrangements/induction and MAF size.
Old May 6, 2009 | 08:00 AM
  #182
David Buschur's Avatar
Thank you for the input on this guys, greatly appreciated.
Now that my MAF size is set back to stock 357.7, the max load I am seeing is about 415, that is at peak torque (which I'd expect). That is at 500 whp/49X ft lbs on our dyno. Injector size is set to 665.
Old May 6, 2009 | 08:28 AM
  #183
Appauldd's Avatar
GOOD LORD ! How did you do that? You are the freekin MAN !
Since max load is kind of in relation to peak boost, I assume you are running a ton of boost?
Old May 6, 2009 | 06:52 PM
  #184
The car is running 32 psi of boost.
Old May 6, 2009 | 07:04 PM
  #185
Appauldd's Avatar
That makes perfect sense. The max load I see is only about 310 based on my 27PSI of boost.
Dave....how about filling us in on a few of your "tuning secrets"? Think of us as your pupils and we are eager to gain knowlege from the master.
Old May 7, 2009 | 08:42 AM
  #186
haha, I have no tuning secrets. It's just fuel and timing.
Old May 7, 2009 | 09:18 AM
  #187
gsrboi80's Avatar
Your car is on what turbo. I see about 320 load at 26psi on a PT61mm
Old May 7, 2009 | 09:34 AM
  #188
fostytou's Avatar
EvoM Community Team
An FP Red RE: https://www.evolutionm.net/forums/ev...formation.html
Old May 7, 2009 | 09:54 AM
  #189
gsrboi80's Avatar
Not Davids car Appauldds
Old May 7, 2009 | 11:13 AM
  #190
fostytou's Avatar
EvoM Community Team
Sorry, not paying enough attention
Old May 7, 2009 | 11:33 AM
  #191
Jack_of_Trades's Avatar
Yet you still didn't answer his question lol. 310 load at 27psi on a stock 8 turbo? I just cross 300 load at 29psi on mine with stock MAF scaling.
Old May 7, 2009 | 01:09 PM
  #192
Evo8Emperor's Avatar
Im seeing usually loads of about 290 at 24 psi with a ported evo 9 turbo. Even with the new meth kit and the boost up to about 26-27 psi and no other tuning done yet its still in the 290's.
Old May 7, 2009 | 03:02 PM
  #193
Hmm, going from 24 psi to 27 psi with NO load change seems fishy.
Old May 7, 2009 | 03:22 PM
  #194
nonschlont's Avatar
+1. I think its ~ 10-20 load points per psi, right? Im seeing 285-290 @ 24psi, and 300-305 @ 24.5-25 w/ the full injen kit and stock MAF.
Old May 7, 2009 | 03:36 PM
  #195
Yah Ive been wondering the same thing. Ive been doing a lot of logging with no wide band of course but all well.
Ive been seeing 26 psi at peak torque sometimes more towards 27 psi and it will taper to a high 22 psi. It doesnt taper bad either it holds out well. Ive also been adding a degree of timing after peak torque in the wot areas.
Its been taking everything with no knock injecting meth. I havent messed with my afr that much but I did lean it out by .2 seeing I have no wide band and decided it couldnt hurt that bad.
