PATCH: CEL Flash on Loaded Knock
Old Sep 17, 2007 | 03:55 AM
  #241
erioshi's Avatar
94170014 v2 zip successfully installed & tested with EcuFlash version 1.32.1399
Just don't forget to update the entry for the immobilizer ..
Old Sep 20, 2007 | 12:05 AM
  #242
elhalisf's Avatar
i know you must be really busy, but any updates on the 96420007?
Old Sep 20, 2007 | 12:15 AM
  #243
tephra's Avatar
Sorry Faisal, I been super busy
I will try and get to your ROMID asap ..
Old Sep 23, 2007 | 12:30 AM
  #244
Max Power's Avatar
Have there been any issues pulling codes with this mod? I have had a cel that has popped up and my code reader hasn't been working - i tried it on a friend's evo and it fired right up.
Old Sep 23, 2007 | 06:41 AM
  #245
Asmodeus6's Avatar
Mine reads fine. I get the 0137 o2 voltage one every once and again I have to clear.
I access and clear them even with this patch.
Its something else.
Old Sep 24, 2007 | 02:14 AM
  #246
tephra's Avatar
not as far as I know. some people have reported minor problems but it all seems to go away with reflashing... maybe ecuflash isn't updating the sectors correctly?!?!?
anyways i would estimate 2 or 3 people in 400 odd downloads have the problem..?
Old Sep 24, 2007 | 07:50 AM
  #247
Jeff_Jeske's Avatar
I have a request.... Is there anyway to make the car "ding or beep" when the cel comes on? Sometimes I don't notice the flashing till its too late. I get out of the gas and then see the cel flashing. It would be neat if we could get the car to provide an audio alert as well.
Old Sep 24, 2007 | 07:56 AM
  #248
tephra's Avatar
lol!
I can get the car to make a 'pinging' noise if you like :P
Old Sep 24, 2007 | 08:05 AM
  #249
C6C6CH3vo's Avatar
That would be eaaaasy - and fun:
Jumper your horn relay through the IC relay contacts - not only will you know when your knocking but so will the car your racing
Beep Beep
Old Sep 24, 2007 | 06:11 PM
  #250
C6C6CH3vo's Avatar
Tephra, your patch worked great very first time.
For both segments of it, the SES light with knock and the 19 psi boost limited failsafe too!
Donation time soon for potentially saving an engine
Great work!
Old Sep 24, 2007 | 06:16 PM
  #251
tephra's Avatar
thats great, and you understood the manual linger thing?
Old Sep 24, 2007 | 08:10 PM
  #252
Asmodeus6's Avatar
Question, the CEL illuminates per each grouping of knock sum you have selected right?
Say you have it set to '3' knock sum = flash. = 1 flash?
So if it flashes 3 times in succession you are actually at 9 knock sum?
I have never seen it flash less than 3 times. Which is why I ask. Every time it flashes it flashes exactly 3 times. It could mean the knock is leading into more knock. (common) But to always knock exactly 9 knock sum no matter what seems strange. I've always seen more variance even within the same tune on knock in the DSM. Sometimes 1* (3 knock sum) sometimes less, or 2* in the same place on a colder night, or up a hill... etc. Mostly it was NO knock in the DSM... the Evo's likes to knock randomly in stupid places. Likely due to tune.
But I'm wondering why any time I knock I get exactly 3 flashes. And I'm good at watching it since I've driven a DSMlink equipped car for years. My peripheral vision is always on that CEL. I have no problems even in the day seeing it.
Maybe the car likes to knock 3* every time? (never knocks at wot tho)
??? I guess I gotta log it while it flashes to be sure?
Old Sep 24, 2007 | 08:15 PM
  #253
tephra's Avatar
Nope
When it flashes that means you have crossed the preset load and knock thresholds.
Old Sep 24, 2007 | 09:04 PM
  #254
oldevodude's Avatar
Great work!
Some of us Already have....
Old Sep 24, 2007 | 09:25 PM
  #255
C6C6CH3vo's Avatar
Nope
Just set the knock values to 1 each, decreased the load to 30% each, and flashed it as a trial. The knock and load parameters will soon be changed to where I think it should (like the original default you had on there) on the way home since it's mostly confirmed that everthings in check. So as for the manual linger thing - I'll just figure that out with a couple more drives and flashes.
I did notice the initial flash took about 40+ seconds to write the block up in high memory to the tables like 2 bytes did, but I'm sure the following flashes will be a flash just the same .
Thanks again!
