PATCH: CEL Flash on Loaded Knock
Old Sep 8, 2007 | 09:58 PM
  #211
tephra's Avatar
its probably easier to just copy your existing modifications (cant be that many :P) to the pre-patched 88590015 rom
Old Sep 8, 2007 | 10:03 PM
  #212
EvoBroMA's Avatar
were talking 10 or more tables where a diff and patch wouldn't take any thinking on my part. i would have to go through all the boost/timing/mivec/fuel tables etc just to figure out all the stuff Jestr changed for my flash.
Old Sep 8, 2007 | 11:21 PM
  #213
Pd1's Avatar
Pd1
Just use the pre-patched version 15 and load your tables into it. It takes maybe 5 minutes.
Old Sep 9, 2007 | 06:29 AM
  #214
bnice01's Avatar
thanks Brandon, ill get around to 15 soonish..
Can you just edit your post to remove my address
cheers
D.
done for ya buddy
Old Sep 9, 2007 | 07:06 AM
  #215
Evo442's Avatar
Thanks to the author of this patch - this rocks!
Old Sep 9, 2007 | 06:35 PM
  #216
andenbre's Avatar
I just wanted to check in to say I successfully used 1.31 to change settings and load into my IX 15 with out errors or issue. the first flash took a long time due to the rom patch but all following flashes are quick and the knock flash works great.
Old Sep 9, 2007 | 07:37 PM
  #217
mchuang's Avatar
Are you getting weird numbers in the x and y axis?
Old Sep 9, 2007 | 07:42 PM
  #218
tephra's Avatar
If you are getting weird numbers (with 1.31) its because your endian is messed up - go through your XML's and change all the "little" to "big".
Old Sep 9, 2007 | 09:03 PM
  #219
andenbre's Avatar
I had looked at all the endian values and they were"big". I remember reading that some endian issues were corrected. no screwed up #s shown and changes made ok
Originally Posted by OpenEcu.org
2007-08-24: Version 1.31 released
added Mac OSX (intel) support! - still some minor Qt issues on the mac...
moved to Q 4.3.0
2D and 3D graphing features working
task pane is hideable and has resizing splitter
significant improvements to the Subaru ECU defintions thanks to merchgod
add better visibility options for invalid or higher user level tables
faster on-demand XML parsing
add relative directory support in the options
read only support for H8/539 based mitsubishis - flashing disabled due to lockout problem
switch to true kwp2000 protocol stack for Subarus
fix endian reversal in metadata parser - old metadata files are no longer compatible!
add shbootmode for SH705x processor recovery
fix asymmetry error in substeps for undo and redo. undo now does steps in exact reverse order, in case two or more substeps operate on the same data (as happens in a 2D interpolation)
fix crash on editing of static values
automatically detect and warn if Subarus are not in the test mode when flashing
Old Sep 10, 2007 | 05:49 AM
  #220
MR Turco's Avatar
Nevermind, got it to work....
Old Sep 10, 2007 | 01:46 PM
  #221
Zamot's Avatar
I can't seem to get the options after changing the xml file (88840016), putting the xml-text at the end of the xml file before </rom>. Restarted Ecuflash, and it is set to developer... Ecuflash version 1.32.
Old Sep 11, 2007 | 11:19 AM
  #222
Zamot's Avatar
Getting confused.. I added the xml-text to the evo9base-file as well, and still didn't show up. Then I removed the folder with my backup of the original xml-files which was in the folder rommetadata\mitsubishi\evo, and then I got the options visible!
Old Sep 11, 2007 | 11:52 AM
  #223
MR Turco's Avatar
goes in the ECU rom version definitions not evo9base. At least that is where i put it and it works.
Old Sep 11, 2007 | 04:24 PM
  #224
Zamot's Avatar
I actually had the same issue when trying to disable the rear O2 sensor. That's why I posted a question:
How does ECUflash use definition/xml-files?
Old Sep 11, 2007 | 04:25 PM
  #225
tephra's Avatar
check your ecuflash settings to see which metadata directory its pointing too - ie the main one not the backup
