PATCH: CEL Flash on Loaded Knock
Old Sep 11, 2007 | 04:29 PM
  #226
Zamot's Avatar
Originally Posted by tephra
check your ecuflash settings to see which metadata directory its pointing too - ie the main one not the backup
I set it to point to the .../evo directory. And I stored the original definitions in .../evo/ORG. Moved the ORG folder to another place AND added the text to the base-file, then it worked. Kind of a mystery to me, so I would like to know how ecuflash uses the definitions (and now also how it selects the directories/definition files), see link in my previous post. But anyway, it seems to work (but haven't had the chance to try it in the car yet).
Old Sep 12, 2007 | 02:43 PM
  #227
mplspilot's Avatar
I wish mine would work.... It just keeps on flashing every time it reaches the preset knock count.... I tried 1.29 and 1.30. ( I didn't like 1.31, it changed the sorting order and put "Miscellaneous" tab on top, when i added 2byte load to it...) It's like it does not change "cel on knock flash time" from that huge amount that the patched rom comes with to whatever i put in there (2000ms). Oh well, at least i got a laptop with a huge knock gauge when i need to know if i get knock or not.
Old Sep 12, 2007 | 05:18 PM
  #228
tephra's Avatar
yup that sounds like the big/little endian problem.
If you are using 1.31 make sure it says BIG in the xml, otherwise use LITTLE...
Old Sep 12, 2007 | 06:49 PM
  #229
gear head's Avatar
96940011 working flawless for 3 weeks now.
thanks for the patch
Old Sep 12, 2007 | 09:58 PM
  #230
mplspilot's Avatar
Ah!
Thanks again for the mod!
Old Sep 13, 2007 | 03:33 PM
  #231
laramie_05MR's Avatar
i have edited the xml and copied the patched rom for the cel flash. my ? is once i order the jdm map sensor all i have to do is edit the xml file or am i missing something? i read the rom flashing thread but that didn't help.
Old Sep 13, 2007 | 03:37 PM
  #232
kreionic's Avatar
As long as you added the extra stuff in the xml in your xx rom ID and then DL the patched rom and switched all your stuff over to that rom the cel knock flash will work. When you get your jdm map just add the formula in the xml of the patched rom you are using
Old Sep 14, 2007 | 05:51 AM
  #233
Thanks. The cel flash is working. I added timing to check.
Old Sep 14, 2007 | 08:41 AM
  #234
rallykid's Avatar
Say I have this modded ROM, and I go to a tuner, to tune my car. He pulls my map, but does not have the XML definitions in his ECUFlash. He D/L my map, makes changes uploads it back up. Any chance something can get messed up? Will this MOD still work?
Old Sep 14, 2007 | 09:06 AM
  #235
mplspilot's Avatar
^ yes, it will still work.
Old Sep 16, 2007 | 10:41 PM
  #236
tephra's Avatar
UPDATED WITH 96530006
edit2
UPDATED WITH 94170015
Old Sep 16, 2007 | 10:52 PM
  #237
dawnduran's Avatar
What is ENDIAN?
I use the newest ECUFlash-Version and must change it in ENDIAN "BIG".
Old Sep 16, 2007 | 10:58 PM
  #238
tephra's Avatar
The xml's packaged with the v2 zips are all ready for 1.31+.
As I said just check that flash time parameter is 3431ms in ecuflash...
Old Sep 16, 2007 | 11:48 PM
  #239
evo828's Avatar
Dave, 96530006 - tested and works well. I've sent you an email confirming the test as well. Thank you.
Old Sep 17, 2007 | 01:58 AM
  #240
blackbichGSX's Avatar
94170015 is working on my car. I was stuck for a little while because I had an old version and the immobilizer was not able to be seen. Seached the forum and then realized I had a version over 1 year old. After updating and re-doing everything it worked and did not blink at start-up like mentioned in the past. Good luck to everyone.
