PATCH: CEL Flash on Loaded Knock
Alright, I am getting aggrivated as all hell, probably because I can't see the trees, only the forest. (Brain Farts?)
I am using the 0011 ROM for my 05..
I put the first line in your new updated 0011.txt file, the following:
"<scaling name="Flashtime" units="ms" toexpr="1000*x/102" frexpr="102*x/1000" format="%.0f" min="0" max="100000" inc="1" storagetype="uint16" endian="little"/>"
into the end of evo7base.xml file (Where all the scaling code lines are), and the rest (table name lines) into my 0011.xml file...
Then open up the new ROM file included in the zip, and I can't see shizzle.
What am I doing wrong? Do all (4) lines of code only go into the 0011.xml file, or does it all go into the evo7base file? I wouldn't think the evo7base because then it would affect all other ROM's..
This is driving me beeezerk, I have never had trouble with and of these mods before.. Help!
Put ALL lines in your 0011.xml file in the ecuflash directory.
NJ,
I think you have a couple of settings switched around in your understanding.
Flash CEL on knock is the setting to turn the feature on or off. 1= On, 0 = off.
Knocksum Required for CEL is the setting of what knock count that you want the CEL to flash. So, if you wanted it to flash at a KS of 3, then you put a 3 here.
Eric
Eric
88590015
Before the update you did this rom did not work on my USDM IX GSR
Flash would succeed but the car would not start, I even waited 10 minutes and unhooked the battery but still it would not start.
Has anyone else had this problem?
