PATCH: CEL Flash on Loaded Knock
Old Aug 16, 2007 | 10:02 PM
  #121
tephra's Avatar
sorry guys, I have been pretty busy with things - at this stage I'm not sure when the current requests will be done maybe next week
Old Aug 20, 2007 | 11:30 AM
  #122
al\lupo's Avatar
Tested 88840016, seems ok even with CEL on due to O2 sensor.
Tomorrow I will try to log with Evoscan to check (I see the CEL light blink with low load during spool up, maybe never noticed )
Old Aug 20, 2007 | 11:57 AM
  #123
Mr. Evo IX's Avatar
For some reason I can't get this mod to work. Is it possible that this map is using the Evo9base file instead of the version15 definitions or something.
Here's the bottom of my 88590015.xml file and a screenshot of the mod file when I open it. No mods section???
<table name="Knock Sensor Filter Map 12" address="4d07">
<table name="TAR" address="7356"/>
<table name="RPM" address="7316"/>
</table>
<table name="Boost Enhancement (Anti-lag) Stop RPM" address="1282"/>
<table name="Boost Enhancement (Anti-Lag) Start RPM" address="1280"/>
<table name="Speed Limit" address="118e">
<table name="Condition"/>
</table>
<table name="2 byte load high bit" category="Misc" address="3ee86" type="1D" level="1" scaling="uint16"/>
<table name="2 byte load low bit" category="Misc" address="3ee8a" type="1D" level="1" scaling="uint16"/>
<table name="LeanSpoolEnable" level="2"/>
<scaling name="Flashtime" units="ms" toexpr="1000*x/102" frexpr="102*x/1000" format="%.0f" min="0" max="100000" inc="1" storagetype="uint16" endian="little"/>
<table name="Flash CEL on Knock?" category="Mods" address="4809c" type="1D" scaling="uint16"/>
<table name="KnockSum Required for CEL" category="Mods" address="4809e" type="1D" scaling="uint16"/>
<table name="Min Load for CEL on Knock" category="Mods" address="480a0" type="1D" scaling="Load"/>
<table name="CEL on Knock flash time" category="Mods" address="480a2" type="1D" scaling="Flashtime"/>
</rom>
Old Aug 20, 2007 | 12:45 PM
  #124
phenem's Avatar
Did you try restarting ECUFlash after you applied the xml definition patch? I found I had to restart ECUFlash to get it to work.
Old Aug 20, 2007 | 12:52 PM
  #125
Mr. Evo IX's Avatar
Yes, I already restarted ECU Flash. Made changes while it was closed. Although I dont think I've rebooted the laptop but I wouldnt think that would matter. I'll try it though. I've completely removed ECU Flash and re-installed it and copied the bottom part of the xml to a new definition file and still no Mods section. Also, it's already in developer mode and I've tried advanced as well.
Old Aug 20, 2007 | 01:17 PM
  #126
tkklemann's Avatar
96940011 Tested and works great, bbbbbuuuutttttttt.......
EvoScan has a fit when I try to log now, and when started it makes the car wig out.
Double checked everything, and it's all right. Seems like the ROM when loaded into the ECU makes EvoScan no longer work...
Hmmm.... Any ideas?
Old Aug 20, 2007 | 02:08 PM
  #127
Mr. Evo IX's Avatar
Hmmm.... Any ideas?
I ran into this when I tried to get 2byte load working on my version 13 map. I eventually gave up and ran the version 15 map so I could use 2byteload - I think the values were wrong and freaked the ECU out. The good thing is when I loaded a different map it just fixed it. I really want to get this CEL knock light going.. that's awesome. I hope someone knows why mine is not working.
  #128
Asmodeus6's Avatar
I look forward to having this feature! (I have it now on DSMlink and its a great warning) Thank you for doing the hard work on this! Those of us used to this knock warning (likely utec/DSMlink guys) have gotten used to keeping a half eye on the CEL as an early warning system. I was worried about losing this and now I don't have to.
Thank you!
Old Aug 20, 2007 | 03:39 PM
  #129
msukach's Avatar
Hmmm.... Any ideas?
I've tried twice w/the 88590015 ROM...and can't get EVO scan to work...I know I must be doing something wrong with the patch but I can't figure out what it is...I'm getting a Aquamist kit and some other things installed tomorrow..so I'm going back to my original flash. Of course, w/the HFS-5 kit, I don't expect to see knock. I may try again to get this to work...I'll keep posting.
Old Aug 20, 2007 | 03:55 PM
  #130
tephra's Avatar
this is your problem... get rid of it
Old Aug 20, 2007 | 06:28 PM
  #131
kreionic's Avatar
Works like a charm with my 15. Thanks again for your hard work. We greatly appricate it
Old Aug 20, 2007 | 08:55 PM
  #132
Mr. Evo IX's Avatar
Thanks!
Old Aug 20, 2007 | 10:39 PM
  #133
codgi's Avatar
Hmmm.... Any ideas?
So you rolled back to the old map and evoscan works again right?
Old Aug 20, 2007 | 10:41 PM
  #134
al\lupo's Avatar
Rechecked, 88840016 works great. No problems with EvoScan.
Thank you
Old Aug 21, 2007 | 05:08 AM
  #135
tkklemann's Avatar
Yeah, the old map works...
What I have been doing, which isn't too bad of a pain in the ****, is to load my old map back in, and use it to tune the car with. Once I am done with my tuning and data logging and am satisfied for the time being, I transfer over all my changed maps to the knock light flash and load it back in until my next tuning session.
Kind of a pain to use one map for the day to day driving (knock light ROM), and then keep transferring back and forth the tuned maps.
I imagine eventually it will be figured out, so I am not really wigging out about it for now. I appreciate all that has been done inregards to the EVO ECU's, so I take what I can get and don't complain.
